Halfords have BMX headsets and Bottom brackets for £1 just now.
They are Diamond back brand. Chrome plated
The Headset is for a 1" diameter fork steerer. It has a 21mm inner diameter on the lock nut. As that suits BMX stems.
Other bikes are 22.2mm. Guess if you was replacing a head set on a different bike you could use the lock nut from your old headset. Or open up the hole in the locknut.
The headset cups have a diameter of 32.6mm, where they fit in the frame.
The bottom brackets are standard one piece crank ones. For BMXs and some mountain bikes. Also fit on the Bratz low rider.
I got 2 headsets and a BB unit today.
