Jun 24, 2005 13:29:39 GMT
my rocco (1.8 DX motor) has always been a bit of a smoker.... usually when cruising along at a lazy speed, if you pull up somewhere and then blip the throttle it'l give out a little puff of blue smoke andthen clear up. just recently though, it's been really bad - lots of smoke and it just keeps pluthering out even at idle. still only really does it when it's been driven 2000-2500rpm for quite a while, sort of cruising in traffic, then let it idle for a bit though. to make matters more confusing, i ragged it up the motorway last night, 70 miles total at (cough cough) mph, and it's a lot less smokey today, possibly even less than when i bought it! i've heard smoke on these engines can becaused by exhaust valves wearing, or seals or summat..... the oil doesn't smell petrolly so i'm hoping it's not rings. anyone have an idea? easily fixable? i have a week off work soon when i can take my car off the road you see
smoking sciroccoDarrenW
@darrenw
Club Retro Rides Member 74
Jun 24, 2005 13:32:09 GMT
Valve stem oil seals? I seem to remember that they're a common problem on DX lumps, but I can never remember whether it's those or the piston rings that are shot when smoke comes out under acceleration
Jun 24, 2005 13:36:14 GMT
naaah accelerating ain't a problem.... that's when there's no smoke, it's when i lift off or just blip the throttle quickly.
the valve stem oil seals.... DIY or new head time?
@darrenw
Jun 24, 2005 13:40:39 GMT
Valve stem seals then - when you lift off the vacuum sucks oil back down the valves into the combustion chamber.
No idea about on the DX, I did them on my Mini years ago and they were straightforward enough! Haynes book of Lies should have the answers... Shouldn't think it'd be too difficult once the head's off...
Jun 24, 2005 13:48:38 GMT
i'll go check out the library fiction section see if they've got the golf/scirocco haynes manual in i'm all excited, going to actually fix something myself!!
Jun 24, 2005 14:45:07 GMT
Breathers first before you go pulling heads Pull the rocker cover off, turn it upside down on the floor outside, pour petrol in it and set light to it. Best done at night Let it go out and cool down, then tap it along the top surface..... all the cacked on curse word thats blocking the breather will have carbonised and will just fall out Repeat with more petrol to make sure. There is also a block breather that gets really badly clogged, but its easy enough to replace. That will help enormously Cheers Dom
Jun 24, 2005 21:03:45 GMT
oooh pyrotechnics and car mending, bonus! i'll try that, cheers dom
filmidget
East Midlands
Mostly Lurking
Jun 24, 2005 22:31:34 GMT
There is a bit of a write up on the above procedure (and why it's necessary) on the No-rice forum if you need it. Might take a bit of searching though.
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
Jun 24, 2005 22:40:50 GMT
got 'rocco HBOL here if you wanna borrow it, and golf too. non-smoking engine too.
Jun 25, 2005 11:10:42 GMT
There is a bit of a write up on the above procedure (and why it's necessary) on the No-rice forum if you need it. Might take a bit of searching though. Hi Phil Thats probably where I saw it first ;D All I know is I did it on the Audi and it works well. How are the rest of the Mafia ? Havent been over there for a while, must pop back and catch up Cheers Dom
Jun 25, 2005 11:28:24 GMT
Guz.... yeah that'd be a brucey bonus, i'll have a read up on it first then give the hbol a whirl.... probably won't be next week, i have a phobia about working on my car in the morning when i'm on late shift could you bring the manuel to rcs? cheers fella and in case it all goes horribly wrong.... your rocco engine.... injection?
Jun 25, 2005 15:13:38 GMT
not doing RCS.
gimme a shout and collect HBOL anytime you want.
1.6 carb model.
