Jun 22, 2005 13:44:20 GMT
Just fitted my Mountney (sp?) wheel to my column and have a few questions.
A) Why is there now a 10mm gap between the column shroud and the base of the wheel? Is this just because i haven't cranked it down enough, or because the old wheels plastic rim covered this gap.
B) Why is the horn push inset bit offset to the left, so it doesn't look like it's sitting central? Is this just a manufacturing defect I'll have to live with?
I'll get some pics in a bit.
Last Edit: Jun 22, 2005 14:04:52 GMT by Lewis
Jun 22, 2005 14:03:23 GMT
Last Edit: Jun 22, 2005 14:03:45 GMT by Lewis
filmidget
East Midlands
Mostly Lurking
Jun 22, 2005 14:16:40 GMT
1. Just the hub/adapter being a different shape to teh original. 2. Dunno - 'cos they are cheap and a bit nasty? Also didn't realise you were a fellow PHer
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
Mountney wheel Q's with pics!DarrenW
@darrenw
Club Retro Rides Member 74
Jun 22, 2005 14:19:26 GMT
Another PH lurker here Yeah, I had that gap between the back of the hub and the shroud when I had a mountney wheel on my Mini. Also, check the little nuts that hold it all together don't come loose, I had a couple that kept doing that and it was annoying having to grovel round on the floor trying to find them... Spring washers helped!
Davenger
It's only metal
Club RR Member Number: 140
Mountney wheel Q's with pics!Davenger
@dminifreak
Club Retro Rides Member 140
Jun 22, 2005 14:19:58 GMT
yeah, what he said. You might be able to centre te cap with a little fiddling It's usually the return spring for the horn that pushes them over, I removed the spring from mine
Last Edit: Jun 22, 2005 14:21:06 GMT by Davenger
Jun 22, 2005 14:20:53 GMT
Cool. I only threw it on today, I'll fettle tomorrow. Got a backbox to hang too, plus carb tweaks to be getting on with. Going to Goodwood on Friday though. Yay! Hello to all Ph'ers
filmidget
East Midlands
Mostly Lurking
Jun 22, 2005 14:35:27 GMT
This is going to sound really wierd... But you didn't visit Tollerton airport (Nr Nottingham) on Sunday did you? 'Cos an immaculate white auto Dolly trundled in while I was there (showing The Boys some planes and helicopters )
Jun 22, 2005 14:46:54 GMT
Sunday................no - I was in a bowl with 130,000 people bouncing around to Greenday Interesting to hear of another sighting though! Don't see too many of them these days.
Last Edit: Jun 22, 2005 14:47:15 GMT by Lewis
Jun 23, 2005 11:49:09 GMT
its probally not made for that car. its might be a british layland fitment but for one of there other cars which has a fifferent plastic bit. mine is a magnum base i think and didn't fit in the hole so i had to whip out the grinder and make it fit then on my dinner break at work i made a centre for it. i have a spare horn mush if you want that which i know fits, actually i have the whole boss with the plastic bits which might fit. pm me if your interested.
Last Edit: Jun 23, 2005 11:59:17 GMT by oldskool
Assumption is the mother of all f**k ups
impmann
Overcoming stupidity is the greatest challenge left to mankind
Jun 23, 2005 12:04:52 GMT
The Imp has the same splines etc as a Triumph wheel - could it be an Imp one? I have a Herald period Formula GT wheel in my everyday Imp...
1964 Hillman Imp 1976 Hillman Imp 1967 Hillman Imp (And a few projects dotted around the country)
Just cos something is good for you doesn't mean its good for everyone - for example Marmite does not make good Dog Food.
Jun 23, 2005 12:24:17 GMT
Meh, I've got used to it now. It fits OK and I think I might just make a black ring up to stick to the back to shield the gap that shows the column, and sorted
