VWDan
VW Jetta MK1, VW Caravelle 1.9TD, Audi A6 Tdi Avant
Jun 21, 2005 10:46:44 GMT
Anyone got a good idea on how to remove the factory stripes as easily as possible? Done one front wing with hot water, but it left all the sticky residue which is really hard to remove. I need to do both sides... Thanks in advance.
If only everything in life was as cool as a retro VW racer.
Jun 21, 2005 10:52:51 GMT
Heat it with a hairdryer for a bit first. They should then start to lift, then peel, keeping the hairdryer angled at it while you pull it back slowly.
Then use a tar remover type product to clean off any residue left on the bodywork.
Last Edit: Jun 21, 2005 10:53:21 GMT by nickb
Jun 21, 2005 11:00:37 GMT
WD40 will remove the residue or you can get proper Sticky Label Remover from RS
Last Edit: Jun 21, 2005 11:02:13 GMT by Grahamini
Jun 21, 2005 11:17:35 GMT
i just used the hot water then thinners. (i did test it before going mad with thinners)
Jun 21, 2005 13:12:37 GMT
I’ve had some success by using an angle grinder to remove the sections of the panel onto which the stickers are fixed. Once they are gone it’s a simple matter to weld in new steel plates, fill with ‘Tetrion’ and respray the car (for a daily ‘smoker’ you can get away with just respraying the sides). This method has the advantage of not leaving a single trace of sticker.
Alternatively the hairdryer method can be successful for the less well-equipped workshop.
Removing stickers/stripesDarrenW
@darrenw
Club Retro Rides Member 74
Jun 21, 2005 13:14:41 GMT
Doh! That's where I've been going wrong. I tried a Dremel but it took me HOURS!
VWDan
Jun 21, 2005 13:15:28 GMT
^^ ;D ;D ;D^^ Think i'll try a hairdryer Thanks for the tips BTW.
Jun 21, 2005 19:01:46 GMT
can you not just carefully apply high-build primer to all areas of the car other than where the stickers are, to make it all flat, then paint over the top?
hair dryer and ordinary car polish will remove the residual sticky. If you use any of the solvent products they will work as well.
lo is th way to go
Davenger
It's only metal
Club RR Member Number: 140
Removing stickers/stripesDavenger
@dminifreak
Club Retro Rides Member 140
Jun 23, 2005 10:21:12 GMT
white spirit usually does the trick for me, basically the same as panel wipe that you get in body shops
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Jun 26, 2005 11:35:22 GMT
can you not just carefully apply high-build primer to all areas of the car other than where the stickers are, to make it all flat, then paint over the top? WARNING this requires considerable skill at bodywork. An alternative would be to buy an identical spec car without the stripes and swap all the mechanical components between the two cars thus leaving you with a stripeless car.
This space available to rent. Reach literally dozens of people. Cheap rates!
VWDan
Thanks for the tips guys - used a hairdryer then RS label remover spray with plastic scrapers to get the gunge off. Got some cool wipes off my dad that are used in the aircraft industry - seem to remove anything from everything. They are carcinogenic though, and ur supposed to use a face mask and not let it come into contact with ur skin. Cleaned the whole car with them...
Jun 29, 2005 10:09:06 GMT
I've quite literally laughed my cock off.
BB
Yesterday at 7:54, pogweasel wrote:
Nothing wrong with creature comforts. If I want masochism, I'll just go and slam my knackers in the fridge door for a bit.
Jun 30, 2005 11:16:51 GMT
You guys should be living in Australia, your smart repilies are total pyssers. I always thought irony was extinct on the www, but here it is alive and kickin!..David
lo is th way to go
Jun 30, 2005 12:12:48 GMT
You're not American, you have no reason for misuse of the word Irony. *n
