pbottomley
If at first you don't succeed, then skydiving isnt for you
Aug 22, 2008 16:47:15 GMT
wanted a ford 105E rear axle ;D ;D what have people got ?? If you aint got a 105E axle then anything same sorta width as a 105e axle that can be upgraded if needed to handle some extra ponies without paying fousands
kevfromwales
the conrod's REALLY out the block now!
Aug 22, 2008 23:05:13 GMT
hey - your in luck!
I have a 105e axle here
I'm coming almost to your doorstep on the 31st of this month!
it's an axle casing, halshafts and diff, but I'll split the diff if req'd
make me an offer as regards price!
cheers - kev
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
pbottomley
Kev your a star, I am after a whole axle not just the case and half shafts.... for now I intend to use it as stock and change diff etc as needs require....
PM sent
