Jun 13, 2005 12:25:40 GMT
I was going to fit a single vacuum gauge in my car, but realised where do I take it off for... Do I tap into the vac. advance for the dizzy? I know I can tap into the manifold but I have two inlet runners so presumably tapping into one will give me odd readings? How the hell does it gauge what vacuum is what on the scale? Can I put two in, and have them for a single carb each, so I can use it to balance them too? Cause in that case (I have a 3-gauge pod) I'll have two full scale vacuum gauges and an oil pressure gauge Cheers!
Last Edit: Jun 13, 2005 12:42:26 GMT by Lewis
Kris
Jun 13, 2005 15:11:10 GMT
It is possible to fit a single gauge using a T-piece in the dizzy vacuum pipe but if you want to run 2 gauges Mini Spares sells a resin spacer that fits between the carb and the manifold. It has a take off for a vacuum gauge and also reduces heat sink into the carb. www.minispares.comPart no: MFA446
Last Edit: Jun 13, 2005 15:14:50 GMT by Kris
Kris
Jun 13, 2005 15:18:28 GMT
A Smiths gauge like this... ..would look nice with the rest of your gauges. This is the same principle but with a different face... Anybody know what its from?
Last Edit: Jun 13, 2005 15:18:59 GMT by Kris
Jun 13, 2005 15:29:06 GMT
I have the one on the bottom - it matches the faces on my existing gauges... I'm going to get full scale ones though, as they will be in front of the shifter and further away, so I'll have one of the Smiths partial-face ones for sale
Jun 13, 2005 15:29:51 GMT
Thanks for the link to minispares btw, great site!
Davenger
It's only metal
Club RR Member Number: 140
Fitting vacuum gauges...Davenger
@dminifreak
Club Retro Rides Member 140
Jun 13, 2005 16:07:55 GMT
Doesn't the Sprint have one? Where do they hook up to?
Jun 13, 2005 16:15:26 GMT
Nah, Sprints have the same config as 1850's, but their speedo runs to 140 instead of 120...
Last Edit: Jun 13, 2005 16:15:39 GMT by Lewis
Davenger
It's only metal
@dminifreak
Jun 13, 2005 16:17:28 GMT
Hmm, could have sworn my vacuum guage came out of a Sprint. It was some kind of triumph, do a search for then in Stags and TR6's
Jun 13, 2005 16:18:46 GMT
Don't think any trummy comes with a vac. gauge - twas strictly aftermarket I'm pretty certain! (deffo know it wasn't the sprint, i had one )
