sowen
Club RR Member Number: 24
I'm liking the progress! The new front valance is really growing on me... This is how I wanted it, just it took a little while to get it right in my eyes. There's still some tweaking to do, but the basic shape is there. The previous style may make an appearance on my brother's mini clubman at some point Great work Thanks I'm finding I spend more time re-doing stuff I've already done now that I've tooled myself up better and have a decent garage to work in, it may take longer, but the end result will be better Loving that nose! This is looking so right now, bet you can't wait to turn wheels in anger? Can't wait ;D There's a little work to do to re-connect the fuel lines and rear brakes, sounds easy but it sits low, and the tunnel has been filled up with the propshaft and twin exhausts, so they need to run under the floor, which means I need to make something to protect them first. You keeping any Rover badges on? Think without it you may well get mistaken for a yank tank by the general public (good or bad?!). Must get off my and fuel up my P6 and charge the battery! No badges but I noticed I could slightly re-arrange the stock 3500S badge to read 350CI Possibly the final body mod (for now at least ) was tidying up the recesses for the twin tailpipes on the rear valance. The edges were a little thin, and I'd already had a go at beating out a symmetrical recess on the drivers side, but it didn't quite look right, so I cut them out larger and welded a bit of fresh steel in place: Then it was given a few coats of primer and a couple of coats of blue It's not been refitted yet as I've still got to finish the exhaust system in the middle where I've added my small baffled muffler, but when it goes on the cherrybomb hangers will be tweaked to put the tailpipes centred in the new recesses. I'm hoping the new muffler will drop the exhaust noise level to something a lot more bearable, but it is a temporary fix to get it on the road until the v8 goes in permanent
Chrisâ„¢
This is clearly filler material.
Loving the attention to detail, what a superb car ;D That front valance goes so very nicely with everything - definitely worth all the effort to get it right!
1989 Volvo 340 1986 Suzuki SJ413 2000 BMW 318ti 2006 Lexus IS250
luckygti
I need to try harder!
Great fabrication work there and I think the front valance really works.
sowen
Thanks for the comments As I say, the front end is almost how I want it now. I think I need to do something around the edges of the air dam just to finish it off, but the basic profile is spot on. The engine is running again, and sounds much better with a small centre silencer fitted. It's not horrifically loud like it was, just appropriately loud ;D . I still need to reconnect the brakes and clutch to roll it outside though. Anyway, I scored a new old stock strengthener panel off ebay for the rear of the boot floor behind the valance. There were some rust spots showing through the black storage paint so I paint stripped it to see how bad it was: Not too bad, so I drilled off the old bent panel to see what it was like underneath: Almost completely rust free . There were still a few small spots of pitted rust so I used some hammerite rust remover gel to clean it all up: I then straightened out the boot floor. It was pushed in almost 1/2 inch, no wonder the valance never fitted right . I cut some small slits in the flange and used some clamps and blocks of wood to pull it back out: Once straight I welded the slits back up: Then put some primer over it all: As I don't have a spot welder, I drilled loads of holes in the new valance panel, clamped it onto the boot floor and welded it on: Once it had all cooled down, I gave some of the welds a quick clean up then primed the area and re-painted it: That's one big job ticked off the list now Here's the rear valance back in place with better fitting tailpipes
10mpg
Club RR Member Number: 204
May 29, 2010 10:55:18 GMT
Trick trick trick...
I love this car it all looks basically P6 but so little of it is actually stock!
it's all the little subtle changesthat one it is back together creates such a great looking thing, nothing is to 'out there' so when it's all done it's just going to look hard as nails and really 'serious'....
May 29, 2010 11:30:38 GMT
Jesus, you make it look all so easy and professional! Love this thread
Awesome work again. If you need some practice at spraying though, I'll let you have my MGB to practice on ;-)
Looks so mean as it is. Would be great once done to get a photo next to a standard P6 to show the differences.
sowen
Christ that looks like it'd follow you down a back alley and rob you at knife point. Best looking custom P6 i've ever seen.
Matt
That's one interesting project, with a lot of unseen work. One thing it does prove beyond doubt is that it's the tiny details that make the big difference, like the cut outs in the rear valance and the profile of the front valance, which will look perfect when you get that finishing kick on the edge. Might I suggest that you continue the satin black on the sill forwards to match the behind the front wheel on the wing? I'd definitely consider adding a black pinstripe at that low bodyline crease along the side too, especially if your fin lights are getting black surrounds instead of chrome.
Even though you plan to drop the back end an inch, I think it looks pretty mean just the way it stands now, especially with the popped bonnet. Definitely a very nice car, earned yourself a Bookmark I think.
PhoenixCapri
West Midlands
Club RR Member Number: 91
Christ that looks like it'd follow you down a back alley and rob you at knife point. Best looking custom P6 i've ever seen. Matt I totally agree, its getting better with every post. Thank god its not black as it'd give children nightmares for the rest of their lives! ;D
sowen
That's one interesting project, with a lot of unseen work. One thing it does prove beyond doubt is that it's the tiny details that make the big difference, like the cut outs in the rear valance and the profile of the front valance, which will look perfect when you get that finishing kick on the edge. Might I suggest that you continue the satin black on the sill forwards to match the behind the front wheel on the wing? I'd definitely consider adding a black pinstripe at that low bodyline crease along the side too, especially if your fin lights are getting black surrounds instead of chrome. That's pretty much the plan, possibly continuing the black around the front. Even though you plan to drop the back end an inch, I think it looks pretty mean just the way it stands now, especially with the popped bonnet. Definitely a very nice car, earned yourself a Bookmark I think. Thanks The rear is just below standard ride height, by about 1/2" - 1", while the front is just over 3" lower. It's difficult the see in the pictures, but it looks a bit odd sitting that high on the rear. Also, the rear looks 'empty' compared to the front. I'm thinking it also needs something like a small ducktail along the boot to finish it off.
Lacy
Without doubt the 'ardest motor I've seen in a long time.....It just looks soooooooo right.
2007 Porsche 987 Boxster S 'Percy' 1994 Landrover 300tdi 90 CSW 'Connie' 2001 Buell M2 'Bertie' 1976 Kawasaki Z1000 A1 'Nobby' ....and my wife has some nondescript modern box of some sort
I've said it before and I'll say it again AWESOME !!!!
ewokracing
Snuffling for food in a river
updates?
sowen
Not a huge amount to update really. Most of the interior is back in place, with a nice new black carpet from Coverdale, the halogen headlights have now got relays powering them so I don't melt the wiring loom, and most of the wiring etc is now tied up nicely. I've got a few electrical gremlins appearing now, like the intermittant oil pressure guage, which is most likely going to be gummy old engine oil, and a dodgy battery that doesn't hold charge which is to be expected as it came off my daily when that refused to start some time ago . There are also some small ripples in the front wings and doors along the crease line where I welded the trim holes up, now clearly visible with a coat of shiny blue paint on so that needs sorting, and I decided to take the heater apart because the foam seals inside were falling apart and there was some light creaping rust under the paint: Some of the parts have been further disassembled from that photo. I'm using hammerite rust remover dip to clean them up, just need to find a bigger bucket for the larger parts now as the smaller bits are almost done, then I will need to find some suitable foam to seal the heater unit back up when it gets reassembled. There are a few more niggly little jobs that need doing before it's ready for an mot, like sorting out a new battery clamp, setting the front tracking, fitting bigger 1/2" wheel studs, fitting a new rear propshaft, panel guarding the wheel arches, making the radiator grilles and many more, but it's definately getting somewhere close now
cyd
I gotta ask.... and I think you might guess why..... how did you get the lowness? Jim
Looks great, but the big mouth in the front valance needs a nice big intercooler in it. Mmmm Rover V8 twin turbo ;D
sowen
I gotta ask.... and I think you might guess why..... how did you get the lowness? Jim The front has uprated 2" lowered springs fitted, with the strut shortened and sleeved in the centre by 1.25". The rear is on standard springs at the moment, but with the extra weight of the Jaguar powerlock, it sits down about 1". This gives about 5" clearance beneath the sump at the front and the differential at the back. I may fit uprated 1" lowering springs all round, which should raise the front 1", and hopefully leave the back where it is. This does however give the front wheels about 2-3 0 negative camber, which I'm hoping won't be a problem as it looks , but if it is a problem, it's an easy fix to adjust the camber on p6's. Looks great, but the big mouth in the front valance needs a nice big intercooler in it. Mmmm Rover V8 twin turbo ;D Never say never
sowen
Aug 17, 2010 21:43:52 GMT
