Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Jun 12, 2005 16:59:38 GMT
Got this (not a moment too soon as the oil in the car was boiling after a track session at Combe on Sat and the pressure light was flicking on at idle after until things cooled down a bit But where best to mount it. One thought was in a J car intercooler stylee on the front of the car under the bumper. Any ideas?
This space available to rent. Reach literally dozens of people. Cheap rates!
Jun 12, 2005 17:04:19 GMT
Why not simply behind the grill?
Jun 12, 2005 17:12:57 GMT
External mounted oil coolers are the way forwards Down on the left under the bumper,.. but tucked in, not full boso style,.. but kind visable if you look at it the right way
Jun 12, 2005 17:17:39 GMT
You get the idea ;D
Where to put this?rustingdeathtrap
@GUEST
Jun 12, 2005 17:22:13 GMT
I was thinking about an external oil cooler on the tina but the only thing that worrys me is if a stone or something goes through it . Messy and expensive.
Jun 12, 2005 17:49:03 GMT
Take the nuberplate off,and mount the cooler under the bumper in the centre. Then paint the number plate letters on the cooler.
Jun 12, 2005 18:05:04 GMT
Are you allowed to have external oil coolers? Just wondered what would happen if you stopped after a long run and some old granny burnt her leg on the cooler while walking past the front in a carpark.
BS Nymph Singer Chamois Coupe Series 3 Landy
Jun 12, 2005 18:09:44 GMT
attach it to the rad if yer got enuff space
if not behind the no plate just cheese grater the plate to let air in............
OR
buy a naca duct and let it into the bonnet and mount in the space in front of the block behind the rad - if theres enuff
2001 HONDA CT110 (NOT RCV)
Where to put this?BenzBoy
@benzboy
Club Retro Rides Member 7
Jun 12, 2005 18:12:57 GMT
Yeah, I'm with the rest of 'em - front mounted, in place of the plate. You could always make a mesh stone guard to go in front to stop it getting holed! Are you allowed to have external oil coolers? Just wondered what would happen if you stopped after a long run and some old granny burnt her leg on the cooler while walking past the front in a carpark. I'm pretty sure it's allowed - the same could be said for side-mounted zorsts like on Locosters, but they don't seem to have any problems.
Jun 12, 2005 19:37:54 GMT
Get an adhesive number plate for the front of the bonnet??
Jun 12, 2005 19:47:42 GMT
When I got My MK1 escort ten years ago it had an external mounted oil cooler in place of the number plate and I was always worried about some scrote slashing the pipe when I used it on the road so I eventually took it off. When its get rebuilt it might have to go back on now ;D
Kris
Jun 12, 2005 19:57:27 GMT
Put it in place of the R/H headlight as you look at it, you'll get by with only one ;D
Shortcut
Jun 12, 2005 20:50:28 GMT
Jun 12, 2005 20:52:12 GMT
I prefer behind the grill but then what do i know ;D
Jun 12, 2005 20:55:40 GMT
"He's not the messiah, he's a very naughty boy!"
Davenger
It's only metal
Club RR Member Number: 140
Where to put this?Davenger
@dminifreak
Club Retro Rides Member 140
Jun 12, 2005 20:56:11 GMT
Mine is mounted in a cutout in the grill. Not my choice, came like it but it does look pretty cool
