Jun 11, 2005 16:36:00 GMT
after some inspiration from that thread about bonnets, and a pic in this months pvw, thought id give it a go on mine . its growing on me, although my bonnet is a little scabby to make it look really good, and i think ill roll the lip to make it look like the bonnet is a flat peice of metal. anyway, i wanted a ratro rides opinion on if it looks any good?
Jun 11, 2005 16:39:52 GMT
Not a fan,... But the bonnet would look ace if you smoothed it
Jun 11, 2005 16:46:41 GMT
i voted nay. i don't think it looks right.just makes it look like the bonnet hinges are knackered. i honestly don't think your car needs it.it looks really good as is. lop 2 more inches off the height and stick a roofrack on.voila, done ;D
Jun 11, 2005 17:01:18 GMT
I voted Nay as well sorry It would look good flat black though and a chequered roof maybe
Jun 11, 2005 17:05:33 GMT
Looks poo.
Sorry.
Jun 11, 2005 17:11:09 GMT
I can see where you're coming from, but it doesnt quite do it for me.
Adam
raising the bonnet?rustingdeathtrap
@GUEST
Jun 11, 2005 17:19:46 GMT
I think you can only get away with that on a beetle, and only then because its a nesessity (sp) (christ my spelling worse and worse)
(Is that how you spell christ?)
Jun 11, 2005 17:31:16 GMT
It doesn't much for me to be honest, your car looked pretty gorgeous the way it was, and it's still well cool, but if it was mine I'd have the bonnet the way it was. If cooling's an issue then maybe you could add a subtle little vent in the bonnet, you know little louvres or something?
"He's not the messiah, he's a very naughty boy!"
Jun 11, 2005 17:33:27 GMT
should only be done to beetles and fiat 500;s
looks like youve smashed it
2001 HONDA CT110 (NOT RCV)
Jun 11, 2005 17:39:35 GMT
Not really to my taste sorry. If you like it thats all that matters. Have you got a cooling problem?
BS Nymph Singer Chamois Coupe Series 3 Landy
Jun 11, 2005 20:42:37 GMT
Need to jack it up higher or not at all, looks like a badly fitting bonnet at the moment, sorry
Jun 11, 2005 21:05:11 GMT
I had considered doing that to my mk1 to help cooling cos it has always run hot but I decided I wasnt keen the way it looked. But if I ever do start rallying it up it will go.
Sorry but another nay from me.
Jun 11, 2005 21:16:37 GMT
I bet he wished he hadn't asked now ;D
Kris
Jun 11, 2005 21:28:47 GMT
No for me too, sorry. Was worth giving it a go though
Jun 11, 2005 22:08:59 GMT
at the end of the day if you like it stick with it. Its your car
Jun 11, 2005 22:34:55 GMT
It wont help cooling at all, will actually make it worse. Scuttle edge of bonnet and front of windscreen is a high pressure area, you will not exhaust hot air from here. Basic aerodynamics..... You need to exhaust hot air to a low pressure area to increase cooling. Beetles actually scoop air, as do 500`s with raised deck lids, but to get the same effect on an escort its the front you would have to raise (High pressure area) and that would only duct air over the header tank of the radiator rather than through the core. this wont help cooling at all HTH Dom
Davenger
It's only metal
Club RR Member Number: 140
raising the bonnet?Davenger
@dminifreak
Club Retro Rides Member 140
Another no I'm affraid mate, looks great standard, don't screw it up
If you do it, it needs to have about 1.5"-2" of air on the trailing edge of the bonnet.
*n
It wont help cooling at all, will actually make it worse. Scuttle edge of bonnet and front of windscreen is a high pressure area, you will not exhaust hot air from here. Basic aerodynamics..... You need to exhaust hot air to a low pressure area to increase cooling. Beetles actually scoop air, as do 500`s with raised deck lids, but to get the same effect on an escort its the front you would have to raise (High pressure area) and that would only duct air over the header tank of the radiator rather than through the core. this wont help cooling at all HTH Dom There are a lot of rally MK1 and MK2 escorts that have been doing that for years I think someone should have told them before now. ;D
lol, I'm still unsure, think ill put it back down untill i can decide if it looks any good. ah well, if ya never tried anythink new, then where wouild we be eh?
