Nick
whats the usual procedure, when you jack up your car using the specified jacking points, but the jacking points are in shoddy condition and you end up deforming the floor of in the areas just above the jacking points near front footwells.
totally hypothetical situation this is. i have not got bent floor in the corners of both footwells honestly.
oh who am i kidding. buggerage, stuff like this really gets up my nose:(.
this weeks car count "5"
Jacking pointsBenzBoy
@benzboy
Club Retro Rides Member 7
I always jack cars up under the wishbones or crossmembers - I don't trust jacking points on cars older than I am! ;D
I always jack cars up under the wishbones or crossmembers - I don't trust jacking points on cars older than I am! ;D Likewise - I don't think I've even used the ones on my 2000 Golf - force of habbitt to use a crossmember / wishbone.........
Nick
same here normally....took a beefier jack couldnt get it underneath enough to get to a crossmember. i thought that the jacking points were in good enough condition but clearly not. luckily the rear end isnt as low so i just jacked it up on the diff.
anyway onwards and upwards as they say....what do i do with the bent floor then now?
Beat it back out from the inside
Nick
i know what would happen if i tried that, i would magically locate more rusty floor and be left with another hole in the floor.
i know what would happen if i tried that, i would magically locate more rusty floor and be left with another hole in the floor. Perferct opportunity to put new floors in then.............
anyway onwards and upwards as they say....what do i do with the bent floor then now? Shut all the doors and windows (of your car) and tape up the door gaps. Then attach a compressed air supply to the exhaust pipe. This will pressurise the interior of the car and pop out the damage without any damage to paint, etc. NO SWEAT
SkoCan
Quando omni flunkus, mortati
i know what would happen if i tried that, i would magically locate more rusty floor and be left with another hole in the floor. Would get rid of the bent bits though. ;D
anyway onwards and upwards as they say....what do i do with the bent floor then now? Shut all the doors and windows (of your car) and tape up the door gaps. Then attach a compressed air supply to the exhaust pipe. This will pressurise the interior of the car and pop out the damage without any damage to paint, etc. NO SWEAT Tip of the week there ;D ;D ;D I always use front crossmember or rear axle. Gotta drive the curse word up on wood first though to get the jack under!!
GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
Jacking pointsGavinJ
@gavinj
Club Retro Rides Member 209
This happened on my e30 after i had some work done, it wasn't until i got home i noticed two big bulges in the footwells!
Get lump of wood wrap it up with an old rag or something and then hit it with a decent size hammer from inside the car and they should go pop back into shape no problem. Mine were very easy to get rid of.
Nick
cool tip gavin cheers:) i'll give that a go tomorrow. (car is currently in pieces not at my house so can't get at it right now.
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Silly boy. The points on a car commoonly (but erroneously) referred to as "jacking points" are in fact test points. There function is simply to allow you to test how fooked your car is come MOT time. The metal at these points is purposely left free of any form of rust protection. Come MOT time you simply raise the car at these points using the supplied testing unit (the jack). Every turn of the handle that is accomplished without raising the car will equate to a hundred pounds on the MOT bill. Simple
This space available to rent. Reach literally dozens of people. Cheap rates!
Davenger
It's only metal
Club RR Member Number: 140
Jacking pointsDavenger
@dminifreak
Club Retro Rides Member 140
I managed to rip out a jacking point on my girlfriends mini, it has them in the sills instead of at the bottom. The sill were supposed to be replaced when we got it, Bullplop! Have to pay the guy a visit with a baseball bat, f*cking mini dealers!
Last Edit: Jun 9, 2005 21:17:08 GMT by Davenger
It`s quite easy to beat the floor back down on a Mini, had to do mine after a trip to KwikF**k a few years back I don`t use the jacking points now, trolley jack with a bit of wood under the subframes for me
Davenger
It's only metal
@dminifreak
Jun 10, 2005 11:47:46 GMT
Her mini has them built into the side of the sill, it just ripped out, so much for them being new sills
Rob
You know, for kids!
Jun 10, 2005 19:32:38 GMT
my old marina saloon had jacking point made of broken biscuits - thats what it sounded like when i jacked it up anyway ! ;D top tip with the compressor tho ! until i got to the end of that advice i thought the exhaust was heading into the cabin !!
