May 30, 2005 18:23:33 GMT
i got loads of advice off iRocco regarding the fitment of this, cheers. its now been fitted. had nothing but problems since the install. it was placed as close to the carbs as i could get it and set to 2 on its little scale.now the car struggles to start and when it does dies as soon as you touch the throttle. i had to set the dial to max (5.5) on the scale just to get the thing to run.ive lost a load of power and have got flat spots in my acceleration that wernt there before. anyone got any ideas? the only thought ive got is it needs setting up on the dyno again to take into account of the drop in fuel pressure? which means another hundred quid that i really cant spare for that. if no ones got any better ideas of how to sort it il take it out and run it as was. cheers in advance ;D
May 30, 2005 18:28:21 GMT
s'not being obstructed by debris is it?
In mine the filter wasn't seated properly and choked the intake - Filter King Fuel Filter & Pressure Reg with the glass bowl.
May 30, 2005 18:47:32 GMT
its not the glass bowl/filter type, heres a pic of the offending article.its got 2 screw in unions and just goes in line with the pipe.
Nathan
Club RR Member Number: 1
fuel pressure reg.peice of sh*tNathan
@bgtmidget7476
Club Retro Rides Member 1
May 30, 2005 19:27:55 GMT
Probably no use at all, But i had the same problem with the pump on my GT used to cut out cus the carb was giving too much back pressure, Easy resolve Get a Suburu one and bolt the curse word on, Much better and sorted my issue out.
Like i Say probbaly nothing the same but helped me
It was running okay at first though wasnt it? I would guess you got a blockage of some type. Take it off and try blowing through it fully open and see if there is much restriction. Try running it without and make sure it still runs alright without just in case a bit of curse word has got into the carbs and blocked a jet
i blew through it before i put it on and it didnt seem like there was a lot of restriction, but i cant blow 2 bar ;D looks like il be off work another week so il have plenty of time to have a bit play. ps my mam wasnt surprised in the slightest at the huge grey patch on her car.
This may sound stupid, but did you plumb it up round the right way? The Filter King type has an 'In' and an 'Out' - if you plumb it up the wrong way it don't work.............
i made sure i fitted it the right way when i did it, but ive still been to check.i have been known to make dumbass mistakes like that. ;D i think I'm gonna take it off, go for a spin then put it back on and have another spin.see if theres any difference.
May 31, 2005 21:19:14 GMT
ive had a bit of a tinker. ive set the dial to 3, so far no probs.
ive had a bit of a tinker. ive set the dial to 3, so far no probs. 3...... as in 3 bar?
i assume the scale is in bar. I'm still thinking about taking it back off.i cant really see how its helping.
3 bar is quite a bit for fuel. I ran mine (for a 45DCOE) just under 1.2 bar. Why did you think you needed one in the first place? And TBH with you, the one you bought aren't the best in the world
id read in a number of different places that if you have twin carbs you should fit a regulator. i should have known better really cos i had bother with my e28 bimmer, and that was down to the swirlpot style reg.it ran fine once id taken it off. when the rain stops I'm gonna go and take it off. cheers for the help, much app'd ;D
mercmad
Those things read in pounds per square inch.i have used them for years starting back around 1971 on a Quad carbed ford V8..i was running seriously stuffed stromberg 97's which leaked constantly.By fitting the regulator and turning it down to the lowest setting ,i still made good HP but stopped the needle valves leaking. I very much doubt you need them with webbers,and when you fit those regulators (which are very old fashoined nowdays) you shouild also fit a small fuel pressure guage at the carb to check fuel pressure,a lean out could and will cause lots of expensive damage.
I tired running my 45 DCOE without a regultaor, and I had a lot of flooding issues - fitted the regultaor and everything was fine.
i only seem to have flooding probs when i turn it off.if i don't give it a bit of a rev before i switch it off its a curse word to get started again. i can live with this.just need the weather to sort its self out.I'm getting cabin fever. ;D
