Jul 18, 2008 20:41:23 GMT
ITS got the original ones fitted up front but the rear is running chevette rostlyes which I'm not fond of. not to mention they are rusty and don't hold pressure to well anyone got any solids? think there 4.5" wide, or even better some vauxhall pattern 4.100 banded ;D
Jul 18, 2008 20:56:16 GMT
Sounds odd. I'm fairly sure these cars would be imperial stud pattern, not metric. Have you checked that the 'chevette' rostyles are not from a Victor or similar? Wouldn't want you barking up the wrong tree.
Jul 18, 2008 21:15:21 GMT
only 70's victors are 4x100
4x101 otherwise
2001 HONDA CT110 (NOT RCV)
probably is 4.101 then may have been drilled out , i want rid of those anyway, so i can get the originals back on there, so to re phrase my original post i need some victor wheels (solids for a 63 model) in possibly 4.101 pcd? ;D cheers guys
MrKiev
If it aint broken don't fix it !
Jul 19, 2008 10:41:04 GMT
Good luck with the hunt, hope ya find some. I would be intrested in the rostyles if you want to sell them?
80mojo
Jul 19, 2008 10:45:23 GMT
Old Vaux are 4x4" so slightly different to the newer 4x100mm
They can be made to go on, but have been known to have a nasty habit of working loose.
'71 Opel GT '72 Manta A '79 Dodge Autosleeper '83 Monza & a half '86 Manta GT/E V6 '91 Astra SXi '94 Carlton Diamond Estate 24v
kevfromwales
the conrod's REALLY out the block now!
Jul 21, 2008 10:06:39 GMT
is this by any chance the same pcd as a viva??
if it is, I think I have a solution for you!
- kev
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Jul 21, 2008 11:10:07 GMT
Vivas are 4x4" (101.6) and I'm pretty sure Victors (not FEs) are too
'67 Vauxhall Viva HB Deluxe
Jul 21, 2008 11:28:21 GMT
is this by any chance the same pcd as a viva?? if it is, I think I have a solution for you! - kev realy?? what?
kevfromwales
Jul 21, 2008 21:56:15 GMT
2 viva 13" plain steel wheels off a ford pop with a viva front end on it! we went up to 14" minor steels to fill the arch a bit better, and I'm about 90% certain they'll still be around somewhere, so I'll do some digging for you howzat??
Jul 22, 2008 16:20:09 GMT
that sir is perfect cheers dude, much appriciated ;D
kevfromwales
no probs - are you going to RR08?? - kev
Jul 23, 2008 16:36:03 GMT
wasnt gonna due to its location and the time of the month (not womens problems but its a week or so before payday, so would be skint if i cant get there dude , whereabouts are you?
pbottomley
If at first you don't succeed, then skydiving isnt for you
Jul 23, 2008 18:02:23 GMT
If it helps I will be at RR08 and have a spare set of 4" Viva rims I would bring if you siad 100% yes you will take them, else I am weighing them in for beer money ;D
Jul 23, 2008 18:52:58 GMT
damn, i need to see if i can get there
MrKiev
Jul 23, 2008 21:16:15 GMT
If it helps, i'm goimg to RR08 can collect them for you and arrange something? Only down the road in Andover
MartinC
Don't like stretched tyres, very low profile tyres & I think a car CAN be too low. Perhaps I'm odd.
Jul 23, 2008 22:05:05 GMT
101mm indeed, humph. At least someone has posted the correct figure of 4 inches...
1937 Standard Flying Twelve
1943 Bedford OYD
1947 Cadillac Fleetwood Sixty-Special
1954 Hillman Minx MkVIII
1956 Austin A30
1957 Vauxhall Victor Super
2001 Chrysler 300M
2002 Rover 75 Connoisseur SE Tourer
Jul 24, 2008 11:25:00 GMT
If it helps, i'm goimg to RR08 can collect them for you and arrange something? Only down the road in Andover that could be a great help dude, how much would you want for doing it? ill see if i can scrounge some doller ;D
MrKiev
Jul 24, 2008 12:44:26 GMT
Ah..... packet of BnH should see me straight? You arrange it and i'll pick 'em up and if i'm on the right shift at work i can deliver them to your door.(Tuesdays drive through Eastliegh with work van)!
Jul 24, 2008 16:19:11 GMT
which set tho? ive been offered 6 wheels possibly guess ill go for the 4 he wants shot of first. as they are needed to be moved. ;D
