e21'er
Due to change of plan I need to sell these wheels - £120 cash sound ok?? Still on the hunt for some lowered springs to fir my e21 BMW 320/6 or possibly someone near Bristol with the skills to take a coil or 2 from my standard springs and reduce this gap as much as possible!
Last Edit: Jul 16, 2008 17:33:04 GMT by e21'er
rob0r
East of England
Club RR Member Number: 104
Jul 13, 2008 11:53:42 GMT
Taking the rear shock/spring assembly off an E21 is less than a 5min job, grinder out a job done. Though it cannot be said to be the same for the front. But if you're swapping the springs anyway you will be doing the hardest work by getting the front springs out in the first place, cutting them is the easy bit.
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
e21'er
Jul 13, 2008 22:11:19 GMT
Unfortunately, I'm partially disabled so can't do the work myself hence the need for someone with the time and skills in return for some paper money
Jul 13, 2008 22:22:12 GMT
2001 HONDA CT110 (NOT RCV)
rob0r
East of England
Jul 14, 2008 11:58:54 GMT
I think tomc is from bristol area 02beemer, might be worth asking if he wouldn't mind helping. Unfortunately I'm the otherside of the country!
e21'er
Jul 14, 2008 23:09:02 GMT
thanks, will try and message him
e21'er
Jul 16, 2008 17:34:22 GMT
Trying to track down Tomc - can anyone help??
rob0r
East of England
Jul 16, 2008 18:50:05 GMT
e21'er
Jul 17, 2008 10:10:50 GMT
Managed to contact him and hooking up next week. Thanks for your help
e21'er
Jul 25, 2008 17:31:26 GMT
bump
