lukeB
May 24, 2005 10:32:18 GMT
My second beetle has engine trouble with its 1200 single port. The car starts first time with no problems and runs and sounds great. After about 30 seconds of running at fast idle, when the engine starts to warm through white/blue smoke appears from both tailpipes, one more so than the other. This is accompanied by oil from the more smoky side, which if the engine runs long enough drips from this tailpipe. Oil pressure is good (about 40 psi) and compression readings are within the 110-130 psi range for all cylinders. Examination of the plugs after running shows they are relatively clean but slightly oily.
Initially I had thought that this smoke was a result of some Redex that I had put down the cylinders after the engine was dormant for a while, or some paint from the exhaust burning off. I had considered that the jetting may be incorrect and it’s running far too lean or something. However the dripping oil from the tailpipe makes me think it’s internal. Compression testing after a squirt of oil in each cylinder increases the readings, on one cylinder by about 30 psi.
Interestingly the smoke smells of burning potatoes but doesn’t really smell typically oily.
Any suggestions will be gratefully received before I take it out and strip it down on the bench.
67' beetle 78' viva
Stu
May 24, 2005 11:39:09 GMT
Interestingly the smoke smells of burning potatoes but doesn’t really smell typically oily. burning potates! Don't know what the problem is Luke, sure someone on here can help though. Fancy having two Beetles!
lukeB
May 24, 2005 14:41:19 GMT
Well obviously I'm going to have to stick some sort of huge, powerful motor in (if I can't fix this 34 hp beauty) Stu-I think you'll agree.
67' beetle 78' viva
May 24, 2005 14:49:29 GMT
Well obviously I'm going to have to stick some sort of huge, powerful motor in (if I can't fix this 34 hp beauty) Stu-I think you'll agree. sounds like a far better solution....
Alain
Dance monkey boy, dance!
May 24, 2005 14:55:22 GMT
sounds like you've done your head gasket To be honest...whatever it is, its gonna have to come out anyway (for the sake of an hour) - while its out, stick something a bit fruitier in (read 1900cc+). No one likes driving gutless bugs ;D
'74 Type 181 - Undergoing 'resto' (albeit friggin' slowly! 2 years and counting...) Wedge Panel Van GTi (Still needs finishing) '85 Passat GL5 Estate (Now Breaking) '87 Passat GLS5 Estate (Daily Hack)
May 24, 2005 14:58:15 GMT
Just for curiousity's sake, anyone got any links for Scooby turbo'd VWs?
Just wondering how easy the conversion is on a T1/2/3/4...
*n
Alain
May 24, 2005 15:01:37 GMT
There's a few scooby powered dubs about - i'll see if i can fish out some info.
It's no straight swap, but it can be done - just with a fair bit of modification and fabrication
Stu
May 24, 2005 15:02:58 GMT
sounds like a far better solution.... Agreed! ;D
May 24, 2005 15:06:14 GMT
I've heard porsche engines just drop straight in....
Alain
May 24, 2005 15:07:22 GMT
was that from the same guy that told you Skodas are the best? ;D
May 24, 2005 15:10:48 GMT
was that from the same guy that told you Skodas are the best? ;D yeah - some bloke down the pub....
May 24, 2005 15:13:11 GMT
Last Edit: May 24, 2005 15:13:35 GMT by rainking
Alain
yeah - some bloke down the pub.... Must have been a madman ;D
May 24, 2005 15:14:56 GMT
Must have been a madman ;D complete loon!
Alain
May 24, 2005 15:17:11 GMT
in fairness... the bloke in the pub isn't far from the truth.... Nah i know he isnt too far wrong ;D
May 24, 2005 15:20:59 GMT
Nah i know he isnt too far wrong ;D looks nice and bling that dude.... Type 4 power.. it's the future...
Alain
May 24, 2005 15:23:20 GMT
yeah it's not quite that clean anymore and the carbs in that pic are too small But that, mated up to the 901 'box and 944 shafts/brakes. how much more porsche do you wanna be whilst still being VW
May 24, 2005 15:30:32 GMT
yeah it's not quite that clean anymore and the carbs in that pic are too small But that, mated up to the 901 'box and 944 shafts/brakes. how much more porsche do you wanna be whilst still being VW sounds spangly!
May 24, 2005 15:38:12 GMT
May 24, 2005 16:53:05 GMT
But that, mated up to the 901 'box and 944 shafts/brakes. how much more porsche do you wanna be whilst still being VW how much work involved to do this? how much would i expect to pay for a gearbox? wheres the best place to look for one? ta ;D
