I'm going to do some re-spraying on the Rocco shortly, but am having difficulties finding the correct paint code for the car............any ideas where it would be?
And when I do find it where can I get the paint from - am considering getting the stuff in cans as I only need to spray the new wing, bottom of the drivers door and the bottom of the passenger wing - although I do have a compressor / gun and done a fair bit spraying in my time so if I could get hold of a tin of the correct colour it wouldn't be a problem.
May 23, 2005 10:05:37 GMT
try looking for a sticker somewhere in the boot matey, they tend to put then in there on the rear most panel for some reason.
Otherwise, I never really looked on my rocco, sorry
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
May 23, 2005 10:11:22 GMT
Never thought of looking there!
I looked at the VIN plate and the plate under the drivers seat, but alas no paint code!
drew
May 23, 2005 10:12:04 GMT
My jetta has a sticker in the boot, and also has it engraved just above the firewall on the bulkhead. Don't know if rocco's are the same though.
The flaps always look a bit gash
HytestA
Cant beat a good bit of rubbing :D
May 23, 2005 15:53:56 GMT
My polo has the paint code on a sticker in the boot, so looks like thats the prime hunting ground. Try Milton Keynes VW headquarters, they might be able to help out with some info if you give them the VIN number. Failing that you could try writing for the old VW birth certificate from VW Autostadt, I'm sure they would do an old 'rocco if you send them the VIN details, just cost you 15 euros.
May 23, 2005 15:59:10 GMT
Been informed all I need to do is take the Rocco to my local VW dealers and they'll be able to look it up on das-computer.
Higgim
May 23, 2005 16:02:15 GMT
Well I would guess Alpine White which is L90E but its worth checking anyway.
Vorsprung Dub Technik
May 23, 2005 16:06:36 GMT
Thanks - I'm still lothed to use Halfrauds spray cans............
Higgim
May 23, 2005 16:08:09 GMT
I buy my paint from VW direct - well its for touching up - not sure if they sell cans, depends how much you need.
May 23, 2005 16:23:54 GMT
my rocco has it on a yellow sticker on the top of the boot lip... should be there unless it's been rear-ended at some point.
My guess would also be Alpine White but my experience of halfords rattle cans on my identically coloured audi was they're less than a perfect match, even on unfaded paint.
May 23, 2005 18:44:05 GMT
^exactly what he said.
ps there's a white Scala in a scrappy up here, and a champagne GT missing its front seats*
*cos they're in my polo ;D
May 23, 2005 20:47:35 GMT
Look in the yellow pages and see if you have a Brown Brothers Motor Factors. They will mix paint for you and have colour charts and mixes to take account of UV aging as well. There will be about 4 or 5 Versions of your particular White ;D Take the car (With a freshly polished bit) and they will let you check the Paint Chips against it HTH Dom
