Jun 20, 2008 19:50:32 GMT
Ive got a weber carb mounted on the inlet manifold of my audi 100 but the rubber adaptor has perished and is letting in air, its making it run horrible!
Ive had a look about the net but cant find anything suitable, does anyone here have any ideas?
I don't know the name of the weber ive got but its the same as the type found on Cortinas.
Last Edit: Jun 20, 2008 19:53:50 GMT by Lankytim
1987 Maestro 1.6 HL perkins diesel conversion 1986 Audi 100 Avant 1800cc on LPG 1979 Allegro Series 2 special 4 door 1500cc with vynil roof. IN BITS. HERITAGE ISSUES.
Jun 20, 2008 20:24:40 GMT
sickerflex round the rubber mate, i no it sounds daft but it works and saves burning a hole in your piston
Jun 20, 2008 21:02:32 GMT
whats sickerflex??
filmidget
East Midlands
Mostly Lurking
Jun 20, 2008 21:16:07 GMT
Sikaflex Wouldn't be surprised if it's a Weber DTML as fitted as a direct replacement for Pierburgs on Golf and Roccos... if so the rubbery bit can be bought from GSF.
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
Jun 20, 2008 21:30:06 GMT
its like windowseal mate
Jun 20, 2008 21:31:48 GMT
Jun 20, 2008 23:04:13 GMT
Sikaflex Wouldn't be surprised if it's a Weber DTML as fitted as a direct replacement for Pierburgs on Golf and Roccos... if so the rubbery bit can be bought from GSF. WHS - I'd be extremely surprised if it isn't just a stock one. Having said that, there are some very obscure Weber kits out there. I once put one on a Mk1 Golf Driver that looked a lot like a Hitachi DCH306 but was badged Weber and fitted/worked a treat so you never know.
Jun 20, 2008 23:08:58 GMT
BTW, that looks like a DGV/DFV or similar
