Jun 20, 2008 17:34:33 GMT
Simple question really... my original Stromberg carb was mounted to the inlet with a rubber and steel spacer. It still had paper gaskets either end to seal though. I'm making an adaptor out of steel to fit the new SU carb. Will it be a problem that I don't have a rubber spacer any more? And what is the rubber part for anyway, to absorb vibrations from the engine? Thanks
slater
Club RR Member Number: 78
Jun 20, 2008 17:55:24 GMT
yeh its for vibration.. The SU wont require one. Some carbs need them some don't for some reason...
Jun 20, 2008 17:55:31 GMT
could be? also could be becuase its cheaper to stamp adaptors out of rubber than ali ;D go for it dean
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
slater
Jun 20, 2008 17:58:16 GMT
some of the older SU,s with the seperate float bowl have a rubber bush between carb and bowl which basicly does the same thing btw. I'm not sure how HIF's get away with it.
Jun 20, 2008 18:29:28 GMT
Thanks, speedy help as ever! The HIF does have a hard plastic spacer, so I assume that will do a similar job. If I have room I'll try to fit it in but things are a bit tight ;D.
Jun 20, 2008 19:09:52 GMT
I was just about to post on the forum on this very subject! My Audi has a weber carb with a rubber mount, but its leaking air and I need another one.... or I need to make an adaptor.
1987 Maestro 1.6 HL perkins diesel conversion 1986 Audi 100 Avant 1800cc on LPG 1979 Allegro Series 2 special 4 door 1500cc with vynil roof. IN BITS. HERITAGE ISSUES.
Jun 20, 2008 20:53:48 GMT
be careful!!! I think its for preventing heat soak!! i.e. fuel evaporates when its hot without it!!! Rwdrules
v6pop
Jun 20, 2008 21:01:08 GMT
Tis true what rwdrules says,helps to slow the heat transfer to the carb which inturn if it gets to hot will evaporate the fuel in the float bowl,can cause problems on hot restarts.
Jun 20, 2008 21:21:13 GMT
Ah, in that case I'll need to try to include the plastic one the SU has somehow... Thanks guys
