Jun 12, 2008 19:31:33 GMT
What this site needs is a listing of common (or at least "available") tyre sizes. No point in knowing the ideal tyre for youlook is for example a 195/45x14 unless you know one is made that size. And trying to use most places online catalogues is usless unless you know either the exact size and speed rating you want or the car it fits as OE. Anyway.... My question to those who know their tyres is what common or not so common sizes are available around a 215/50x14 Anything above an S rated tyre would be fine. Failing that are there 205/55x14s, 195/40x14s etc. Who knows whats out there?
markbognor
Club RR Member Number: 56
Jun 12, 2008 20:45:54 GMT
I often use ebay to research tyre size avalability, typ in the knowns, width/ /wheel diameter for instance and see what comes up. Usually it'll be the common sizes too, then just search eleswhere for that size.
I've often wondered why there isn't some sort of online database of current tyre sizes. Surely it would help the suppliers as well as the buyers.
Jun 12, 2008 20:47:29 GMT
Can't help but the bloke at the tyre place almost spat his tea out when I asked for a pair of 175/80 R14s earlier! Not a common size apparently...
markbognor
Jun 12, 2008 20:48:53 GMT
Can't help but the bloke at the tyre place almost spat his tea out when I asked for a pair of 175/80 R14s earlier! Not a common size apparently... I'm sticking the steels back on the merc sometime soon, so I'll be doing this shortly too.
Jun 12, 2008 20:53:34 GMT
I use the my tyres site to see if a certain size is available. 195x45x14's are available, 205x55x14's are not, and 195x40x14 are available Linky be here www.mytyres.co.uk/start.html
205 GTi Mi16
205 XS - Now in filmidget's signature
Clio dci 80
I've found in life if someone is an idiot, they generally stay and idiot.
Odin
Jun 12, 2008 20:58:03 GMT
I look them up on mytyres usually because their stocklist is pretty extensive. The responses I got trying to get 185/45 R15s for my Panda locally were mostly of the 'you must be wrong, they don't exist' type. Readily available from mytyres however. Edit: paulmi16 replied whilst I was typing, there.
Last Edit: Jun 12, 2008 20:59:15 GMT by Odin
bortaf
Jun 12, 2008 21:03:13 GMT
R.I.P photobucket
Can't help but the bloke at the tyre place almost spat his tea out when I asked for a pair of 175/80 R14s earlier! Not a common size apparently... Whaaaat?! Tyre man is a chump. Modern Golfs use this tyre size as well as our beloved Mercedes. I agree with AK - some kind of resource would be good. I'm out for a pair of 175/70R15 tyres. No idea if they exist or not! ;D
sooty
Jun 13, 2008 22:38:06 GMT
Can't help but the bloke at the tyre place almost spat his tea out when I asked for a pair of 175/80 R14s earlier! Not a common size apparently... Isn't an 80 profile the standard profile of a car tyre?
2016 Dodge Charger Scat Pack 2008 Jeep Liberty Limited
There's a difference between 80 profile (as in 175/80R14) and un-profiled (if that's the best way to refer to it!?) as in 175R14. That works out to be 82% profile. Not much difference really, only a few mm.
175/70x15 used to be around in the 70's/80's...one of my saabs had 'em. Unobtainable now - closest now is 175/65...
'98 e36 316i lux '97 mx5 harvard '87 Saab 900 T16s
There's a difference between 80 profile (as in 175/80R14) and un-profiled (if that's the best way to refer to it!?) as in 175R14. That works out to be 82% profile. Not much difference really, only a few mm. I've always been under the impression that a tyre with no quoted aspect ratio was 80%...so a 175/80/14 is just a 175/14.
Can't help but the bloke at the tyre place almost spat his tea out when I asked for a pair of 175/80 R14s earlier! Not a common size apparently... Not hugely common granted but as 175/14 and 175/80/14 are bot the same size I think you should be able to score some reasonably easily enough. Could be old age and bad memory but weren't 175/14s standard fit on the Triumph 2000 amongst some others?
Corsa Apology Champion 2014.
Jun 14, 2008 10:17:40 GMT
I've heard the 80/82 thing before.
Jun 14, 2008 10:39:27 GMT
195/40 are a size
Jun 14, 2008 12:32:37 GMT
Jun 14, 2008 14:53:18 GMT
^^ Great link! ^^ Might try them next time. I tend to get part worns usually as my car eats tyres. ;D
