I'm attempting to repair a BMW instrument pod - the capacitors have gone and need replacing. Now, I'm confident enough to have a crack at soldering in new capacitors... I just need to know what they look like! Any ideas? I'm thinking they are these are them...
Oh, I've looked on the BMW forums but the repair guides don't seem to cover this dash, as it's a late one.
Them's the ones.
rtlkyuubi
Low and Slow
yea they are capacitors, but as you can see, there are many shapes to them:
Odin
That sounds like a world of pain to me. I've never had much success repairing PCBs.
Good luck!
Be careful not to put too much heat into them when soldering as they have a tendency to explode sending fluff everywhere ;D
Mr K
is the bottom right one burnt? the chip above it looks black and sooty on one side too?
p.s. am i the only person that thinks circuit boards looke like little cities with tower blocks and roads?
Last Edit: Jun 6, 2008 18:33:41 GMT by Mr K
is the bottom right one burnt? the chip above it looks black and sooty on one side too? p.s. am I the only person that thinks circuit boards looke like little cities with tower blocks and roads? No because i'm sure i've seen an advert somewhere with a car driving around a circuit board ;D
Yes, they are the only three caps I can see from the photos. When replacing, remember that most caps are directional, so if you put them in backwards, you'll ruin the board. They are usually marked with a black band or a + on one leg.
There is nothing more expensive than a cheap Mercedes
Thanks chaps! I'm actually wondering whether it's worth getting someone professional (or at least has done more soldering than a couple of Vellemann kits and half a Megasquirt...) to do it. Depends on how much it would be. But at least I know what I'm looking at now!
markbognor
Club RR Member Number: 56
is the bottom right one burnt? the chip above it looks black and sooty on one side too? p.s. am I the only person that thinks circuit boards looke like little cities with tower blocks and roads? Yeah that one deffo looks dead. fault finding someoneelse's pcb is a nightmare, if it looks dead change it but there's not much else you can do without some pretty hardcore electrical knowlege. Year the pcb cities is the current tv licence add - your cities and addesses are all on our computer database type thing.
Soopra
p.s. am I the only person that thinks circuit boards looke like little cities with tower blocks and roads? nope, my son thinks that too
For mine is the Supra, the power and the glory...
Mr K
ah glad I'm not the only one! i cant think of the advert, will look out for it.
hope you can get this sorted! let us know how it goes.
