May 30, 2008 20:47:38 GMT
i don't know what the best tip i was given was but i got the perfect tip of the day here ; brushable seam sealer AKA grey stripe made by upol . DO NOT under any circumstances use a brush to apply it ,makes a damm fooking mess which than you will have to remove taking triple the time you wasted on brushing it on . INSTEAD , get one of them white plastic gloves on and spread it with the most convenient finger . like butter on bread it applies clean and smooth as ferk ,i can deffo say its the best sealer i have used so far . TOP STUFF !!
May 30, 2008 21:30:47 GMT
If you're swapping a tire onto a rim yourself and you need to get it to seal against the rim, a squirt of quickstart into the tire and a lit match will do the trick (with a large bang which makes it much more fun.
1995 Range Rover 4.0 1995 BMW 320i Saloon 1989 BMW 325i Touring 1991 Mercedes 300TE-24 1991 Mercedes 190e 1970 Sunbeam Imp Sport
1966 Valiant 200 Custom 1964 Ford Fairlane 500 Station Wagon
May 30, 2008 22:45:40 GMT
I don't know what the best tip I was given was but I got the perfect tip of the day here ; brushable seam sealer AKA grey stripe made by upol . DO NOT under any circumstances use a brush to apply it ,makes a damm fooking mess which than you will have to remove taking triple the time you wasted on brushing it on . INSTEAD , get one of them white plastic gloves on and spread it with the most convenient finger . like butter on bread it applies clean and smooth as ferk ,i can deffo say its the best sealer I have used so far . TOP STUFF !! Hmmm, I've found a decent sized artists bruch applies it alright. Doesn't give that "factory" finish though - might try the latex glove technique when I do the other side of my car. Good tip!
Ooh Lord, I've had loads over the years. Off hand my favourites have been spraying aerosol paints into the cap of the can and stirring hard with a modelling brush before applying to small areas of bodywork (with brush) that you don't want to get over spray on or are too small to spray anyhow. Also the felt pen treatment for pre-auction cars is another cracker, as is the (self taught) 'cure' for Rover 1.4 K series engines prior to going into an auction ;D
Corsa Apology Champion 2014.
