madspikes
Wrong wheel drive!
May 27, 2008 21:13:30 GMT
Interesting little project. I'm a big fan of 'stick and supercharger on it!' as I'm current installing a Eaton 45 into 205 Gti... Always nice to see someone elses take on an install.
Once you get your setup working, you can always improve the design and tailor it more to your requirements.
Mad.
Last Edit: May 27, 2008 21:15:23 GMT by madspikes
slater
Club RR Member Number: 78
19?? Metro 998 superchargerslater
@slater
Club Retro Rides Member 78
May 27, 2008 21:19:47 GMT
Is the entire thing mounted on that one bit of manifold tube? madness!
bootsy75hst
"scrap the caddy clyde"
i do have an old mg unit that maybe used in the future, i've put it on the 998 as its such a sweet little motor and i like how they rev compared to a 1275. Thats a good point slater i will keep an eye on it when i mount it all. Thanks for all the comments
"when the going turns weird, the weird turn pro" hst
PhoenixCapri
West Midlands
Club RR Member Number: 91
19?? Metro 998 superchargerPhoenixCapri
@phoenixescort
Club Retro Rides Member 91
I wish you every bit of luck on the install, but I dare not pass comment on the Jonspeed kit now I've seen those close up photos......
Just out of interest how much did the kit cost?
May 28, 2008 10:52:28 GMT
To be far to the Jonspeed kit, there not as expencive as the Vmax scart kit, but is done in a very similar way (jonspeed kit is a rip of the V-max every ones doing these days) I belive the Vmax kit has a extra brace. I belive there inlet manifold is abit thicker. I belive he is working on a way of getting a charge cooler in to help with the intake temp. I have heard of the Carbs iceing up being placed at the front, just somthing to watch out for. I would Highly recommend going to Mega joltz for the ingnition to make the most of you set up. Check out www.turbominis.co.uk theres alot of people on there with superchargers and ignition kits. but really go to Mega joltz. you will get a big diffrence over a dissy thats not matched to the engine.
1987 Mini with Suzuki Swift GTI engine 2005 BMW E91 320D Touring
bootsy75hst
May 28, 2008 16:42:07 GMT
a grand. ive heard of petrol staying at the bottom on the inlet but people who run them turn the tickover up and this seems to cure it. i have got electronic iginition to go on it too. There was a moggie minor in PPC that was using a supercharger mounted high up but in a blow through arrangement, he was using an intercooler. i' would be tempted in the future in raising the blower up so i could have an intercooler, its just a thought anyway..............mel gibson has alot to answer for!
May 28, 2008 18:29:54 GMT
Unless its programable Electronic igintion it running from a ECU it won't do the job right. the advance curve will be WAY out. I run a highly moded 1380 a-serise in my mini and it took a long time to get a dissy modded for my advance curve. I'm going to MJ over this winter 1 to make space for a front mounted rad and 2 to improve my ignition systerm to keep up with the rest of the engine build. will be £100 very very well spent.
bootsy75hst
it will be better than points though, but for a 100 quid I'm intersted in the megajoltz, do you have any more info?
bootsy75hst
May 29, 2008 18:58:52 GMT
hi , i've had help from my friend from the past 3 days and i've managed to get the gti interior in which was an easy bolt swap, 'm quite pleased with it, almost like it came from the facotry like that. The fuel pump is wired in and working although i had a bit trouble with my earth. Today we ripped the head off changed the head bolts put the decompression plate on, swapped the tappet chest covers around, and put the bottom pully on. After my tea i got straight back on with it, now i put the exhaust manifold on just for mock up and that was fine, then the charger. The charger was fowling the heater so i heated the the heater up with a blow torch and bent it in wards and that was sorted, its still a close but i think i'll get away with it. But i've hit a bigger snag, the water pump hose's are going to be in the way of the charger belt, i tried a couple of different configuations but it looks like I'm gonna have to get some pipe and rubber u-bends to sort this hiccup, but hopefully after a scrounge round my local scrapyard i should have it sorted.
slater
@slater
May 29, 2008 19:04:40 GMT
never quite goes to plan does it! ;D good luck with sorting it.
May 29, 2008 19:57:12 GMT
Good luck with sorting that out!
TBH, I prefer the original seats because they go with the rest of the trim.
[/color][/b] [/CENTER]
Ether
May 29, 2008 20:26:05 GMT
Best of British, mate. Think of the whiny forced induction noise!
May 29, 2008 21:30:43 GMT
Nothing beats a whining Metro... Mind you, a whining curse word can be all the same.
bootsy75hst
May 30, 2008 16:23:41 GMT
well it looks like i'll have both ha ha
bootsy75hst
