For sale i have a large collection of mini/metro turbo bits and some other bits from turbocharged cars that may be of use.
3 metro turbo plenums
1 montego/maestro plenum
4 metro inlet manifolds
1 metro T3 turbo on manifold
1 metro turbo exhaust manifold
2 fuel pressure regulators
1 link pipe
1 metro turbo carb on manifold
3 intercoolers 1 serck,
1 SAAB 900,
1 TATA loadbeta.
1 Rover 620 turbo on manifold(water cooled)
1 ford sierra 1800 TD turbo
1 metro turbo head(sodium filled exhaust valves)
2 turbo exhaust elbows
1 standard turbo cam (used)
1 fuel pump
Assortment of intercooler pipe work from various cars SAAB,Volvo and mitsubishi.These will be handy for when you plumb your turbo up as there are loads of bends and angles to work with.
1 1293cc engine block machined to take a Group A head gasket and has an all steel 4 bolt centre main cap and comes with a minispeed phase 2 turbo cam,however it does need a rebore as some water got into 2 of the bores and caused some piting but it will rebore ok.it only did 2000 mile before this happened.
1 box of assorted bits for your turbo conversion such as gaskets and an exhaust clamp which is new and some double valve springs.
1 stripped T3 turbo thats only good for spares.
I've been collecting this stuff for years and i finally realised i'm never going to start let alone finish this project so i'm clearing out the lot.I'm asking £500 ono for the lot which if you bought this all individually it would end up costing more the work on the block alone is costing nearly as much if not more!
Call me on 07905 831801 or PM me
1 link pipe
1 SAAB 900,
1 TATA loadbeta.
1 fuel pump
