BiAS
Insert witty comment here
Club RR Member Number: 147
Marina suspension?BiAS
@cheeqi
Club Retro Rides Member 147
May 20, 2008 22:43:29 GMT
As it says, is this Marina front suspension? Marina axle? on this Any ideas greatly appreciated, I'm gonna have to order parts for it and I could do with knowing what it is.
(car+wheels)-rideheight=WIN
May 20, 2008 22:48:07 GMT
Yes mate, it's all Marina stuff apart from the front tie bars (steering arm ends added) and the front dampers (probably from the kit). The axle is Marina too - interesting link set fitted there...... Its nice to see one of them with the proper wheels on, usually the ones I've seen have plastic covers over the steels or a set of modded wires... What do you need?
Last Edit: May 20, 2008 22:49:36 GMT by marinanut
Rover Metro - The TARDIS - brake problems.....Stored Rover 75 - Barge MGZTT Cdti 160+ - Winter Hack and Audi botherer... MGF - The Golden Shot...Stored Project Minion........ Can you see the theme?
Marina suspension?stealthstylz
@stealthstylz
Club Retro Rides Member 174
Are you sure thats not a Mk5 Cortina axle the link setup looks the same. Don't whatever you do put polybushes in the rear arms.
Matt
May 21, 2008 15:32:11 GMT
Are you sure thats not a Mk5 Cortina axle the link setup looks the same. Don't whatever you do put polybushes in the rear arms. Matt Nope, thats a heavily modded Marina axle (I've seen enough.....). I looked into one of these kits yonks ago when my 1300 died, but even then they were ££££££! PS; just discovered a set of polished Bugatti alloys to fit Marina/Triumph on t'net! Wibble...... ;D
Last Edit: May 21, 2008 15:37:29 GMT by marinanut
BiAS
@cheeqi
May 21, 2008 16:48:52 GMT
Cheers Marinanut, it's coming into work next week for 'recommissioning' and from the look over last night it'll need bottom swivels, a steering coupling and probably some brake bits. Were those wheels commissioned specifically for that kit? I've never seen them on anything else. Apparently there are 100ish of them worldwide, 25ish in the UK. That particular one is number 7. Can't believe how much money they fetch.
have fun doing the bottom swivel as the bottom arm is also the spring....
I had a van come to me one day with a bottom trunion done, wasn't any the wiser jacked it up and flipped the wleel nuts off only to have it fire the wheel at me
May 22, 2008 20:58:01 GMT
BiAS
@cheeqi
May 23, 2008 13:56:55 GMT
Cheers dude, muchly appreciated.
May 23, 2008 14:41:22 GMT
Marinas have suspenson? Having driven an 1800 Deluxe estate a few years back I had assumed thay there were 4 strategically placed blamanges at each corner.
