May 18, 2008 21:45:46 GMT
Just having a few thoughts about upgrading brakes and wheels on one of the projects and I'm looking to move from 4 stud to 5 stud(but sticking to 114.3 PCD) to reduce other cost within the project. What are the pitfalls of doing this modification that I might need to be alert to with regards to maintaining the structural integrity of the components etc.
Cheers
2014 - Audi A6 Avant 3.0Tdi Quattro 1958 - Chevrolet Apache Panel Truck 1959 - Plymouth Custom Suburban 1952 - Chevrolet 2dr Hardtop 1985 - Ford Econoline E350 Quadravan 2009 - Ovlov V70 2.5T 1970 - Cortina Mk2 Estate 2007 - Fiat Ducato LWB 120Multijet 2014 - Honda Civic 2.2 CTDi ES
slater
Club RR Member Number: 78
Redrilling Hubs/Discsslater
@slater
Club Retro Rides Member 78
Umm well the first thing is to check that theres attulay metal where you need to drill the holes. Alot of the time there isnt! ![:-/](//storage.proboards.com/forum/images/smiley/undecided.png)
kee
May 19, 2008 11:19:36 GMT
it's impossible to redrill a 4 stud hub to 5 stud, unless you utilise one of the existing holes, in which case the pcd would have to stay the same.
gonna have to have new hubs made or somehow put the hubs off the 5 stud car onto yours
May 19, 2008 11:57:26 GMT
"impossible" is a very broad statement. Unlikely is a better one... ;D I'm sure I've seen it done 4 to 5 lug. Many hubs just don't have enough metal in them to pull it off anyway, you end up having to drill one new hole so close to an existing hole that you risk the stud mounting failing.
Like Kee says most times you either swap hubs over or find someone whiocan supply you with a blank. On RWD cars you will also have the ballache of having to replace the halfshafts to change PCD.
mattt
May 19, 2008 14:02:56 GMT
![](http://img511.imageshack.us/img511/5044/keep024ly5.jpg) can be done, its what I'm gonna do on my cressida. I know technically it shouldn't be as strong but plenty of people do it without problems. Guess it just depends how you view cut springs, stretched tyres, welded diffs and all the other baby killing car mods?
Last Edit: May 19, 2008 14:03:33 GMT by mattt
May 19, 2008 15:09:37 GMT
hubs are round in part because that way they are in ballance as they spin. I have no idea if that is going to cause a problem in use but it kinda looks really wrong to me.
mattt
May 19, 2008 15:13:14 GMT
yeah, like I said, it looks wrong but is probably only noticeable if you did some science-like test. plus its close to the hub so shouldn't matter as much?
This spacer/adapter is interesting: ![](http://shop.yumetenpo.jp/goodsimg/rim-corp.com/goodsimg/FTE056/main.jpg) It's got a reversible bolt hole!
Seth
That's to fit something six stud too - so something quite heavy duty!
I have 4 stud drums redrilled to 5 stud, they are the same pcd though, 4x120 to 5x120 i think, whatever porsche pcd is.
If you sticking with the same pcd you should be ok. Have a look inside and see if there are strengthening ribs in the drum.
Nathan
Club RR Member Number: 1
Redrilling Hubs/DiscsNathan
@bgtmidget7476
Club Retro Rides Member 1
May 21, 2008 10:13:09 GMT
Would it not be worth welding up the old stud holes?
kee
May 21, 2008 11:13:57 GMT
extra holes shouldnt make too much difference to strength, unles sof course you have hundreds of em ;D circles are the strongest shape, thats why people spaceframe cars with tube rather than box ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
May 21, 2008 14:04:38 GMT
That's to fit something six stud too - so something quite heavy duty! Hiace van. ![](http://image.blog.livedoor.jp/anan119/imgs/2/9/29a080b2.jpg)
