Apr 24, 2008 17:24:20 GMT
I got a rover 620ti Turbo with an idle problem. its too high. It sits at 1400rpm and will eventually settle to around 800rpm if its left stationary for long enough, but if you prod the accelerator it will sit back at 1400rpm again, process will repeat each time. I have checked the throttle cable and spring return. I was thinking throttle position sensor? I have head that sometimes the ECU can get 'confused' Its the wasted spark type engine so has no dizzy cap and that. Any thoughts on ths are appreciated. pic of engine bay
Apr 24, 2008 17:35:55 GMT
The idle as far as I can remember is set via the ecu. In our case it was an overactive stepper motor playing silly sods. Other than that I don't know.
205 GTi Mi16
205 XS - Now in filmidget's signature
Clio dci 80
I've found in life if someone is an idiot, they generally stay and idiot.
street
6.2 ft/lbs of talk
Apr 24, 2008 17:55:51 GMT
Maybe an air leak? Although I wouldn't have thaught that would be intermitent.... easy to check anyway though to eliminate it
Apr 24, 2008 19:06:40 GMT
Rover Metro - The TARDIS - brake problems.....Stored Rover 75 - Barge MGZTT Cdti 160+ - Winter Hack and Audi botherer... MGF - The Golden Shot...Stored Project Minion........ Can you see the theme?
bstardchild
Club RR Member Number: 71
Apr 24, 2008 19:10:05 GMT
Idle control valve would be my favorite if it has one and it's likely that it does
Failing that an air leak after the throttle body can do this too but the idle wouldn't return back down to normal so find the ICV
Apr 28, 2008 18:32:30 GMT
Had a look and cant find an idle control valve - I did check for leaks and all seems well?
its doing it as I drive along like the thrttle is open as if I go up a hill the car continus to 'speed up' even though my foot is off the pedal? how strange?
I going to change the coolant temp sensor if I can find a rover parts dealer nearby.
other than that I don't know?
Apr 28, 2008 19:26:52 GMT
Turn the ignition on. pump the acc pedal 5 times. fire it up. see if it helps. this resets what the ecu see's as closed throttle position.
coolant temp sensor is probably the easiest/cheapest to try. failing that its probably best to get it plugged in. getting the stepper set up properly will do it the world of good.
Idle air control IIRC is all part of the throttle body. (the big alloy contraption with the multi plug just above where the boost hose connects.
Current cars:-
2001 P38 Range Rover 4.0 V8 (economical family run about) 1980 Mini Clubman estate (very much in a state!)rolling shell project 1976 Reliant Robin saloon 1998 kawasaki zzr 600 (the commuter)
