Apr 15, 2008 21:45:33 GMT
The ones in the 760 turbo - any good? based on the B series? Whatabout the ones in the 850 and similar tanks? And can they be RWD'd easy enough?
No particular reason for asking... Just got to be tossing a "wonder what if" idea about
;D
turbo Volvo engines....rustingdeathtrap
@GUEST
Apr 15, 2008 23:00:43 GMT
760 four pot is what i'm sticking in my tina at the moment. Supposed to be good for 180 brake. They are a heavy engine but not much worse than a pinto. The t5 engines can be turned around using a straight six manual box, if you can find one.
naffa
Kingfisher Blue on 18"s
760 turbo is what i'm moddin @ the moment. Very strong, very cheap and aesy to tune to 300bhp. Good artical in this months PPC magazine about them
Nathan
Cheers Nathan
Filthyjohn
Currently on the road: 1/11
Apr 16, 2008 11:35:54 GMT
The redblock is what you want for cheap easy power. Wouldn't put one in a really light car because they're really heavy, but a 360 is only 1100kgs and doesn't feel unbalanced or owt. If you're using a T5 for RWD you'll need a straight 6 sump and pickup, cut down a bit as the 5 is just a 6 with a cylinder lopped off to fit transverse layouts. Hope that helps.
'95 Volvo 945 Turbo
'87 Volvo 765 TIC
'75 Opel Manta A 2.0 16v,
'86 Volvo 360 turbo,
'62 amazon,
'67 MGB GT.
Apr 16, 2008 13:11:03 GMT
180 sounds quite low for a 740, considering Volvo sold kits to convert an amazon/140 B20 pushrod into a 180BHP NA beast! I have heard of 500+ from a turbo lump, but never really looked into it to know how driveable/expensive/doable it is.
Remade In Australia thereimaginarium.com.au
Apr 16, 2008 14:10:23 GMT
180bhp for 740's, but then less and less (160bhp odd) for later 700 and 900 series cars as they added emissions controls. Any of them are very easy to get over 200bhp, with hardly any modifications. Around 300bhp comes without opening the engine (just turbo, injectors, ECU etc). Beyond that, 500bhp is possible but expect lots of engine work. Even with 'only' 180bhp they make remarkably impressive progress. Everything you need to know is on the US Turbobricks forum, but note that they used different engine managment systems in the US for some models.
Apr 16, 2008 14:33:56 GMT
