Needed for a scratchbuilt car project.
ANY wood greater than 50mm x 50mm in cross-section, however long it is. NO planks or anything smaller than those dimensions. Cheap as chips if possible..
Also (long shot) need use of a bandsaw for less than an hour to cut said wood into 175mm lengths!
Ime in manchester so around there please!
Edd
Shelby Daytona - Scratchbuild project.
can you give me a better idea of what you are looking for & what you are going to use it for what as I MIGHT be able to help send me a pm if you want sorry no band saw though
Last Edit: Apr 1, 2008 12:45:21 GMT by all4show
find me on facebook to see photos of things I'm selling off !!! All Forshow or ebay all-4-show-uk
you don't need a bandsaw to cut 2x2 up !!!
Allforshow - Its for spacing out sheets of plywood (to put is simply) exactly 175mm apart! Guz- For my purpose i do.. Accuracy is important! And as i need to do the same thing roughly 100 times a bansdsaw would shorten how long it takes me!
Wood quality is not too important.
Edd
markbognor
Club RR Member Number: 56
I wouldn't bother with a band saw if its accuracy you want, use a circular saw (table not hand held).
Get on friendly terms with a member of staff from your local secondary school's technology department.
