As titled, need some 80mm Internal Diameter pipe for my AFM. I cant have a standard one because I have a larger throttle body than normal and AFM isnt in normal place.
Needs to be 35CM or longer ideally.
You never know, someone might have something kicking about. If I can only get 70mm ID flexible pipe then that would be the next best thing as I could heat it to fit the throttle body or buy a reducer.
PM me if you have anything that might be of use!
Cheers
Alex
Cheers
Alex
