AS above, the engine in out 98 Mondeo ST24 is dead and we are now is search of a replacemnt.. ideally under 100k, must be the MK2 version or later as its too much hassle to change the MK1 intake system over etc. As close to Bedford as poss but i am happy to collect. What have you got? Failing that, would also consider a complete runner and pull the motor myself. Cheers Lee
I'm not saying I'm Batman, but have you ever seen me and Batman in the same room together?.........
And no, I'm not Ben Affleck!
not looking good so far...
HELP!!
cortinadale
luvvly jubbly!!!!
you will be lucky to get a good one. there a proper wibblepoo engine
We learned from an early age that...people who change signatures suck balls ;-) 1978 Cortina 2.3 ghia
have you looked on fleebay as there seams to be a few going for spares on there........
you will be lucky to get a good one. there a proper wibblepoo engine Thanks very much.
have you looked on fleebay as there seams to be a few going for spares on there........ All sorted now thanks, got a 80k miler unit arranged with history and new clutch and gearbox.
owelly
Iknow where there is a complete car with 12months MoT for about £600. Any good??
cortinadale
luvvly jubbly!!!!
just saying mate, ive had 3 and not been impressed with them. they don't seem lively for a v6 engine!! plus they have no end of troubles!
Dale, tis alright, i know they arent teh best, lookedinto it when we first bought the car, but the wife loves it hence why its being replced not just broken up for parts etc... All sorted now anyhow.
Mar 11, 2008 15:15:49 GMT
If you were closer I'd have popped round and helped you get it fitted, for such a tight squeeze its a pretty easy job to throw one in - while the engines out of the car it'd be a good idea to whip off the upper and lower inlet manifolds/throttle body etc and have a good session with the clutch cleaner/wet n dry Jamie
Mar 12, 2008 10:22:43 GMT
Cheers Jamie.
Funnily enough the engine thats coming is manifold-less anyway, which is handy as it allows me to fit my new IMRC!
Might give it a go with the cleaner and wet and dry...
Planning on taking it out the top rather then faffing around with the subframe etc....
If funds streched to it i would do the suspension at teh same time.. but sadly priorities....
