Jun 28, 2009 21:35:54 GMT
Further progress was made this week, with the fabrication of a gearbox cover made by modifying the original Minor one with sheet steel and fibreglass, topped off with a BMW E34 5-series gearlever gaiter: Then it's a matter of fitting the rear dampers and finishing the electrical work...
mirafioriman
My next project.......
Jun 28, 2009 21:55:13 GMT
Looking good. I have a number of Fiat twin cams (in Fiat bodyshells) now theres a novelty! Great engine and looks right at home in the Minor, which looks rather tidy.
Jun 29, 2009 21:26:07 GMT
Thanks, Mirafioriman! I recall the Mirafioris from when I was a teenager, indeed, I had a model of a rally spec (Abarth?) one. Pity that so many suffered the dreaded rust
mirafioriman
Jun 29, 2009 21:29:17 GMT
I have that model too. My Father had a 131 when I was growing up which is the reason why I like them.
Good to see that engine/car combination - works very well. Nice solid shell by the looks of things too.
Doesn't look like too much more work to get it on the road...
It was my late teenage dream to have a twin cam powered minor. Ended up with that engine in a Skoda Rapid instead...
There is nothing more expensive than a cheap Mercedes
Apr 15, 2010 22:57:48 GMT
Jun 11, 2010 17:20:07 GMT
Jun 15, 2010 21:43:40 GMT
love these cars .... colour suits the saloon
loving the dub
Jun 16, 2010 22:26:56 GMT
Thanks fella. Not sure what particular shade of green that is; Almond Green, possibly, unless anyone knows better?
Yes, that's Almond green. Same colour as the traveller I passed my test in.
Last Edit: Jun 17, 2010 8:16:24 GMT by moggyman
A little more progress was made on the Twin cam this week, removing the original external Fiat thermostat, fitting a 74 degree Celsius Mini one in the cylinder head as recommended by Guy Croft, and getting a local sheet metal fabricators to aluminium weld one end of the T-piece that protrudes from the head. To this has been fitted a 1/8" brass radiator bleed valve, to enable the removal of air locks which I suspect were causing some overheating. Then, the correct Paraflu Fiat anti-freeze was added, which from the local Fiat stealer was only 97 pence more per litre than basic Halfrauds stuff!
Jul 17, 2010 21:51:50 GMT
A little more progress made over the last couple of days, MIG-welding in the top mounts for the rear telescopic (Spax adjustable) dampers, and fitting the shocks, so the chassis is in effect complete. Also fitted the rear lights, with new lenses. Wiring is the next major task. Don't suppose anyone has a copy of the dashboard rocker switch wiring for a Mini, by any chance?
That minor is aweome. I love the way it just loks stock, but it would smoke most at the lights
Jul 18, 2010 10:09:42 GMT
chaz
Jul 18, 2010 19:33:44 GMT
Love what you doing to these cars mate have a soft spot for them, I once owned a split windscreen traveller for a couple of years.
Jul 20, 2010 22:20:51 GMT
Thanks for those encouraging comments, folks - much appreciated!
qwerty
Club RR Member Number: 52
1970 Morris Minor Travellerqwerty
@qwerty
Club Retro Rides Member 52
Two lovely looking cars. I love how they both look so standard! I'll definitely own another minor at some point! I loved my old one.
Cheers, fella More progress made on the wiring front, getting the dashboard/speedo sorted. I discovered that the original bimetallic strip voltage regulator for the fuel gauge was duff (open circuit), so I opened it up, removed the old gubbins and built a solid state regulator using an LM317 and a couple of resistors to give a steady output of approx. 10 volts. So, the car now has ignition warning light which shows the Magneti Marelli alternator is working, working fuel gauge and the speedo itself is also operating. This is all useful stuff from the psychological point of view, as it creates the impression of a far more complete car!
Aug 14, 2010 21:00:41 GMT
Well, a setback occurred on Wednesday, when I was attempting to sort out the non-working indicators. I fiddled with some connectors below the steering column, which brought the windscreen wipers into full play, with dual speeds, all functioning perfectly - great, I thought, as previously they had only worked on one speed. Then, while focusing my attention on the indicator stalk wiring, I noticed a burning smell, but couldn't see anything amiss. I nipped out to take a look under the bonnet, to see the length of loom running to the wiper motor smouldering away nicely right on top of the battery!!! Had to quickly disconnect the rather hot battery live to prevent total meltdown. Fortunately, damage was confined to that section of the wiring loom, so this has now been replaced, but what caused it remains something of a mystery... I did eventually get the indicators to work, following a rebuild of the indicator stalk and hazard switch, a bit of rewiring, and experimenting with an assortment of flasher units. So, at this stage, all lights work, also the horn and windscreen washer motor, and the wipers work again on both speeds but have for some reason lost the ability to self-park; duff limiter switch on the bottom of the motor, I think... Speedo amber lights work in conjunction with the indicators - not normally the case on Minors, for some odd reason Also, I have tidied up the engine bay:
Aug 20, 2010 21:25:58 GMT
I discovered today that the propshaft clonking noise when driving was due to the close proximity of the rubber doughnut against the side of the transmission tunnel, which in a Minor, is quite narrow. It was free to spin normally without touching, but under load, it would just catch the metal edge of the doughnut - not good. Also, the clutch was slightly touching the steering rack (a cutout has to be made in the Fiat gearbox bellhousing to clear the rack), making for graunching noise and vibration through the steering column - double not good So, today I removed the gearbox cover and cut away the section of transmission tunnel that was contacting, and redrilled the rear gearbox mount so that the back of the gearbox now sits 10mm lower, giving the clutch a tad more room to rotate freely so I hope this will solve the problem. Also added 10mm spacers to the centre bearing mount to match the gearbox lowering. While the gearbox was exposed, I replaced the duff reverse light switch with a working spare and wired it to ignition controlled live, so I can later easily fit a reversing lamp.
