jamesd1972
Club RR Member Number: 40
Sept 21, 2018 10:25:17 GMT
You could wire them as DLR's ? People seem to have built up reliance on them a bit - why people can't look in the mirror and go ooh its a bit bright behind me dips might be useful or people have their visors down best make sure they can see me I don't know. (pet peeve sorry !). When is the first timed outing ? James
Sept 21, 2018 10:55:20 GMT
Blumin Heck Mark you could bring down a zeppelin with those.
They are a touch bight if you want to dim the down give them a rub with a scotch-bright pad to frost them over.
Sept 21, 2018 12:15:00 GMT
James, I missed the Hot Rod drags so I don't know now. Off to Popstalgia this afternoon. The do make a 5/21w version of the same bulb for daylight running lights but it would require extra wiring to make it work. Pete, not possible as they have about 10 SMD's built into them. Anyway, I like them this bright Maybe worth looking at the LED headlamp conversion as well too.......
Last Edit: Sept 21, 2018 12:16:18 GMT by blackpopracing: stupid fat fingers tpying worng letters!!!
Sept 23, 2018 22:21:10 GMT
Very tired after going to Popstalgia for the weekend, so I'll just leave this here for now.....
Sept 24, 2018 8:13:22 GMT
Very tired after going to Popstalgia for the weekend, so I'll just leave this here for now..... Hmm - Pity that period building in the background does not match the period look of the pop
Sept 24, 2018 9:25:55 GMT
Hmm - Pity that period building in the background does not match the period look of the pop FTFY
Sept 24, 2018 9:44:49 GMT
Very tired after going to Popstalgia for the weekend, so I'll just leave this here for now..... Hmm - Pity that period building in the background does not match the period look of the pop When I saw this at sunrise this morning, my first thought was a Jaguar, Aston, Bristol, Range Rover, Rolls (insert vehicle of choice here), etc., would pull it off. Somehow though, I love the contrast. We need more of 'this car shouldn't have this backdrop' pics. Besides, the grass needs cutting.
Sept 24, 2018 10:00:50 GMT
Try this one - my parking spot in the hotel
Sept 24, 2018 10:03:13 GMT
It was a good weekend - I tied with 2 other cars for participants choice, Mick Taylor with the Banshee Racing fordson was the one whose name got picked out of the hat to win the award though but at least I still have the knowledge that all 3 of us won really. These were the other two I tied with.
Sept 24, 2018 10:09:36 GMT
It was a good weekend - I tied with 2 other cars for participants choice, Mick Taylor with the Banshee Racing fordson was the one whose name got picked out of the hat to win the award though but at least I still have the knowledge that all 3 of us won really. These were the other two I tied with. Can’t be coincidence that they both have bigger scoops!!! I like the fact that yours inquite subtle with a quick glance, then you look again and start noticing details
Sept 24, 2018 10:24:57 GMT
I bet only one has passed the IVA though!
Great pictures, can we have some in the custom Car Magazine style from the 70s/80s! if your old enough to remember you will know what I mean!
Sept 24, 2018 11:32:04 GMT
The pic in front of that stately home is amazing......
The Millenium Volcon"Get yourself a Volvo if that's what you really want, you might be dead next year. In the meantime, you could be going sideways in a gigantic land barge."
Sept 24, 2018 11:46:09 GMT
Last Edit: Sept 24, 2018 11:47:16 GMT by Deleted
Sept 24, 2018 11:47:53 GMT
I bet only one has passed the IVA though! Great pictures, can we have some in the custom Car Magazine style from the 70s/80s! if your old enough to remember you will know what I mean! Absolutely, know any girls up for it?
Sept 24, 2018 11:50:33 GMT
WELL!!! that's 2 hours of my life I'll not get back
Sept 24, 2018 11:53:27 GMT
Sept 24, 2018 12:03:00 GMT
I bet only one has passed the IVA though! Great pictures, can we have some in the custom Car Magazine style from the 70s/80s! if your old enough to remember you will know what I mean! Absolutely, know any girls up for it? Unfortunately no not at my age!
Now the Anglia has a few miles under its belt have any teething problems shown up or are you on top of everything?
Sept 24, 2018 12:33:35 GMT
No real teething problems, it sounds 'cammy' inside the car (but not outside) which has worried me for a while, but logic is now overruling paranoia in accepting its just the way the exhaust sounds and to live with it. It's done 2,300 miles so if it were a cam issue it would have destroyed itself by now. It has a slight harmonic vibration at 55mph, possibly prop not perfectly balanced? so the easy solution is to drive it at a different speed. It's noisy!!! not so much engine as general wind roar, so steps are afoot to try to seal the doors better - they are watertight, but not wind tight. Engine has run a little warmer than I'd like - it's run at the correct temps but only because the electric fan has worked more than I think it ought to. Since i moved to trans cooler under the radiator and the weather is cooler it's hardly used the fan in the last 300 miles and its barely got past 195f. Oil temps get a bit high at continuous high speed cruising - 250 degrees f at 80 mph after 10 mins but will drop quick if I back off, so 'maybe' an oil cooler is needed, though it runs at 210 or less if under 60. It might be because I welded a 3mm plate on the sump for protection -this may be stopping the sump cooling properly, so a finned ally sump may be a solution as well. Springing is still too firm, so more springs to order to experiment with softer ones. Otherwise a few squeaks to eliminate and thats about it really. Checked fuel consumption this weekend as I thought it was about 15mpg, turns out it does 20mpg so well happy with that!
Sept 24, 2018 14:03:33 GMT
That's good then no major issues just a few tweaks, most new cars have more issues than that!!
Good fuel economy as well, bonus!
Sept 24, 2018 14:13:42 GMT
Try this one - my parking spot in the hotel Better - but I think it would look great pictured parked outside / alongside the large illuminated 'Mclaren' sign at the entrance to the factory in Woking (just down the road for Mark) but with a nice 'My Car Is Better Than Yours' sticker in the side window
