been able to start work on the golf again, now that I'm at home,
managed to strip all of the inner wings and door posts, por15 and primer them, then coat the whole wing with black stonechip
also managed to ALMOST get the front antiroll bar on, painted all up with pinky red translucent polybushes (to match my purple steering rack ones, red and yellow wishbone mounts lol)
on the last bolt however, i managed to snap it, but luckily it was the bracket for the wishbone and not the bolt that goes into the body, otherwise that would have been a REAL pain.
i threw a coat of jizer over the engine today to try and read some of the numbers and figure out what the engine actually is, so ill put the pictures up and see if anyone knows, because it didnt seem clear to me...it says 1.8g2 on the rocker cover in a tippex pen, so I'm thinking the engine has been replaced at some point.
once i know what it is, i can order a clutch for it, and give it a good clean up, I'm going to steam clean the whole lot, get a new carb gasket, belts, filters, oil, oh and new fuel lines!
then ill just remove and paint a the components one by one, just give the block a light coat of oil because unless i spend alot of money...
its all going to peel off anyway, so i thought id make it look smart, yet practical considering my budget and also bearing in mind that its only an engine and I'm not really that bothered if its not chromed up to the nines, id just like a nice clean working engine, because I'm not into car shows, lifting up bonnets all that much, i want a tidy runabout that looks retro, so theres only so far I'm going to go, however the engine does look really clean (probably becaue of the amount of grease all over it) so should turn out looking good, watch this space...most importantly of all I'm going to make sure there is no fuel leaks this time, and put two big fire extinguishers in the car!
anyway, pics do the talking...
you can see the brown patch where the fire has penetrated through...
as you can see, quite a bit of pitting/surface rust in the next few photos, I'm glad i managed to catch in just in time...
started some wiring..
so onto the nicely fresh clean inner wings...thank god thats one less place on the car covered with the dreaded waxoyl.
stonechipped (looks weird in the flash light)
now onto pics of the engine numbers....any help figuring out what it is?
like ive said before... mainly the progress is hinging on the fact i don't have the money to buy the parts, so come easter/summer time it should start progressing faster, but hope u enjoy the read all the same
how it stands for now, being guarded by the hilux..
JJ
