Aug 28, 2007 20:28:06 GMT
Fulda ZE-501, £23 a corner, delivered from Germany, from MyTyres.co.uk.
Seems their prices change all the time, I just looked and they only have these Fuldas, and at £29 each, when I chose mine, they had about 6 different manufacturers to choose from?
Since the rear is transverse leaf, I need to get it decambered, or just remove it and leave the rear on bumpstops?
aij29
Aug 28, 2007 20:42:23 GMT
Hi You can lower them a couple of inches by extending the mounting bolts, It`s hard to explain but if you google "fiat 128 lowering" You should be able to find it Cheers Adrian
Just something i googled Lowering the rear of a 128 is easy, because of the ingenious nature of the transverse leaf-spring design. It's a simple matter of spacing the lower A-arm away from the spring perch. The most common method for doing this is to remove the stock mounting bolts, and replace them with longer (upwards of 3-inches in length) bolts that can accept a sleeve-type spacer. The thickness of the spacer determines the amount of lowering. Without too much trouble, this spacer can be swapped, providing for quick rear ride height changes.
Last Edit: Aug 28, 2007 20:51:12 GMT by aij29
dugong
One Of Us Will Live To Rue The Day We Met Each Other (Wire : 2008)
VIP,
turbo it and go round Mallory at RR '08.
That would possibly be one of the best things ever.
Ether
Cripes, this is an interesting project!
Good to see some time being spent on these puppies. Was there ever a Yugo race team?
VIP, turbo it and go round Mallory at RR '08. That would possibly be one of the best things ever. The long term plan is either Uno Turbo power, or a 1500 Fiat lump!
Hi You can lower them a couple of inches by extending the mounting bolts, It`s hard to explain but if you google "fiat 128 lowering" You should be able to find it Cheers Adrian Just something I googled Lowering the rear of a 128 is easy, because of the ingenious nature of the transverse leaf-spring design. It's a simple matter of spacing the lower A-arm away from the spring perch. The most common method for doing this is to remove the stock mounting bolts, and replace them with longer (upwards of 3-inches in length) bolts that can accept a sleeve-type spacer. The thickness of the spacer determines the amount of lowering. Without too much trouble, this spacer can be swapped, providing for quick rear ride height changes. Nicely done! I'll be looking at that. I do have my eye on some truck bumpstops, big flat rubber affairs, may work well a spacer!
Sept 10, 2007 19:11:33 GMT
Hello, what's this? A parcel? For me? From Serbia? Mmm, lots of Yugo goodies I've ordered from a Yugo Owners Club member... I've got a lot more than I actually asked for! I ordered: Rear red/clear lenses Clear side repeaters Front clear lenses Pair of window winders Spare fuel pump crystal headlights (I know they dip the wrong way!) I got a load of bonus items though: Pair of genuine Yugo mudflaps Extra window winder One internal door handle Numerous new badges a peach air freshener (?) and some cool original Yugo brochures! Tried out the new clear lenses.. Rear Sides Front Not bad, if I do say so! Here's a few pics of the car so far...
qwerty
Club RR Member Number: 52
1992 Yugo Tempo 0.9qwerty
@qwerty
Club Retro Rides Member 52
Sept 11, 2007 7:50:32 GMT
Looks sweet! Shame these have so little following. Can look really cool.
Sept 11, 2007 8:03:12 GMT
Modding is huge in Serbia/Croatia/Bosnia. You Tube "Yugo Racing"
Sept 11, 2007 8:29:17 GMT
Looks like its coming together nicely Fiat fire/turbo power by RR08??
Sept 11, 2007 8:47:19 GMT
Looks like its coming together nicely Fiat fire/turbo power by RR08?? Here's hoping! Really want to find a crashed/too rusty to repair Uno Turbo for not silly money, so I can rob the engine, box, ECU, front struts etc.
Mr Vincent
Hiding In The Shed ......
Sept 11, 2007 12:13:47 GMT
whats the address for the owners club - My window winder came off in my hand 2 day!!
Rusty`s Motorcycles
OLD SKOOL RETRO CAR CLUB
Sept 11, 2007 12:17:34 GMT
What colour is it? I have a grey or black one you can have for postage monies! The owners club is in Serbia, the website forum is www.yugofanclub.com but most posts are in Serbo-Croatian, so don't expect to learn much! lol
Mr Vincent
Sept 11, 2007 12:22:10 GMT
Think its blue - but I will check later thanks!
Rusty`s Motorcycles
Mr Vincent
Sept 11, 2007 12:25:17 GMT
wish I could speek Serbo-Croatian, how did you order them bits??
Rusty`s Motorcycles
Sept 11, 2007 15:28:07 GMT
I have an English-speaking Serbian who now lives in Germany, who was going home to visit his folks, pick them up for me!
Sept 11, 2007 22:12:57 GMT
this is the car i'm most looking forward to seeing finished at the mo
SPLIT RIMS ARE FOR WINNERS
Oct 21, 2007 14:40:44 GMT
Well, seeing as no-one wanted to buy it, I've decided to run it around til the tax runs out and then scrap it. So, I don't need to worry about getting through an MOT again, therefore I can lower the rear traveller way. Ripped out the rear leaf, and stuck some DAF bumperstops between the rear arms and stock bumpstops to keep the rake level. Got some nice rear camber too, now handles like a go-kart!
Oct 21, 2007 17:30:41 GMT
I'm sure someone here will take it off your hands instead of scrapping it - do sometyhing like project Pandamonium.
*n
Mr Vincent
Nov 18, 2007 13:40:08 GMT
have you still got it? - where about are you? Postcode etc..... I will buy it off you rather then you scrap it! Sorry I didn`t get back 2 u on the winder, but I ve been off line for a bit - I am Now a Dad!
Rusty`s Motorcycles
