Apr 12, 2013 21:02:47 GMT
Well I went down to see the car tonight and discuss the next steps ;D So I thought I`d snap some of the work too Lubor made all this rather than use the "Repair panels" as he felt he could do a better job Pedal box mounting now fully welded in Rear lwr 1/4 panel, again from scratch So As you imagine, I'm pretty pleased with that ;D Back down there tomorrow to make a proper jobs list, there will be about a weeks delay as they are back working on Ecotricity again but that`ll give me time to find a front panel and make some decisions re arches
Last Edit: Apr 12, 2013 21:07:26 GMT by CR500Dom
Sept 24, 2013 20:58:29 GMT
Just bouncing so I can find it again !! There has been some more progress on the shell so I'll get some pics up soon Cheers Dom
Sept 24, 2013 21:06:00 GMT
Have been following this over the years, glad to see that it is continuing! Will be so worth all the effort when its done.
Sept 24, 2013 21:20:08 GMT
Me and my dad are restoring my kadett city too atm. and i know your pain. my dad fab'd his own headlamp surrounds etc etc. and my uncle made his own wing mounting rails from scratch for his HS, because the rep panels were shocking.
'72 Opel kadett coupe
'77 Opel kadett city sr
'92 Peugeot 309 Gti Goodwood
'93 Peugeot 205 GL auto
'88 Citroen BX 16v(Breaking)
bstardchild
Club RR Member Number: 71
Sept 25, 2013 17:22:03 GMT
Just bouncing so I can find it again !! There has been some more progress on the shell so I'll get some pics up soon Cheers Dom Waits patiently..... Not really but sounds better
Sept 28, 2013 7:56:55 GMT
Some pics as promised Pedalbox area is now finished, complete with a mounting point for a FBW throttle The car had been involved in a little bump at the front at some point in its life, so the front panel was a mess of filler and had been ravaged by tin worm. Also the front crossmember was a little bent too, so I looked for another front panel, which are about as common as the proverbial poor quality wobbly children's play pony do do, and when they do come up............. They are €500ish !!! So I looked for an alternative Riesse motorsport in Germany do most of the kadett panels in GRP or carbon, so I thought I would try one of their lower front panels And get Lubor to fabricate a nice lightweight, bolt in crossmember too I also wanted to be able to run sill stands on it for service and wheel changes etc, so I got some tubes and strengthening plates added while we were at it ! So there we have it, small but significant steps towards a finished shell ready for blasting !!! Cheers for looking Dom
Sept 28, 2013 8:32:59 GMT
Almost as excited for your build as I am for my own
PhoenixCapri
West Midlands
Club RR Member Number: 91
Sept 28, 2013 11:20:22 GMT
Looking good! Are the through sill bars alsofoe mounting the seats to?
Sent from my GT-I9305 using proboards
bstardchild
Sept 28, 2013 18:38:53 GMT
I also wanted to be able to run sill stands on it for service and wheel changes etc, so I got some tubes and strengthening plates added while we were at it ! So there we have it, small but significant steps towards a finished shell ready for blasting !!! Cheers for looking Dom Excellent I may have to borrow that idea Update and photos worth the wait thank you
Sept 28, 2013 18:58:41 GMT
It allows you to just jack up under the diff and front xmember and lift the whole car with 2 jacks. Stands will be 570mm high so enough room to drop a gearbox out easily.
Also allows me to use a bilstein quick lift jack in the tubes to lift the car on too.
Stands will also be a bit trick as well, let's put it this way......... They won't weigh much, they won't rust, and there will only be one set like them anywhere ;-)
Cheers for all the positivity folks, it really does help keep the enthusiasm going for it.
Next on the list is rear arch repairs and probably new engine mounts on the chassis to allow room on the exhaust side for the drysump pump Cheers Dom
Edit: sorry Andy, the tubes are just in the sills, they don't go right through to the tunnel. I've already got the seat tubes in and mounted, although they may come out for some nicer ones yet ;-)
bstardchild
Sept 28, 2013 22:33:36 GMT
Stands will also be a bit trick as well, let's put it this way......... They won't weigh much, they won't rust, and there will only be one set like them anywhere ;-) So no chance of a spare set like......
mantamutilator79
I love the smell of kerosene in the morning….
Sept 29, 2013 18:52:49 GMT
Loving this thread!! The Wilwood pedal box is a work of art, compared to my home brewed affair in the Manta. Just a question, are you using a servo / servos with this set up? I am running an early VW Polo servo coupled to a VW Golf master cylinder. If the servo should fail, then I'm a bit buggered as there just isn't any available. With the planned re-birth of the Pulse8 Manta, I want to upgrade and the Wilwood set up looks ideal.
Pete
Sept 29, 2013 20:25:30 GMT
Stands will also be a bit trick as well, let's put it this way......... They won't weigh much, they won't rust, and there will only be one set like them anywhere ;-) So no chance of a spare set like...... Well put it this way, they don't need to be made from what these will be made from, but this was part of a deal/work I did at the tail end of last year. I could get a set done in steel though as the design is done ;-) They are available from a load of different places already. Cheers Pete No servos on here, and it will be quite a heavy pedal as its only a 5:1 ratio but the car should only weigh 7-750kg so should stop ok
Oct 13, 2013 23:12:56 GMT
It's nice to see one of use making some progress! Good job. I hope to get moving with mine again shortly.
It's nice to see one of use making some progress! Good job. I hope to get moving with mine again shortly. Good stuff !! Are you still after a cage ?
Yes mate I am - how long did gary need to complete you 5 link work?
Nov 18, 2013 13:20:31 GMT
Yes mate I am - how long did gary need to complete you 5 link work? Sorry fella, only just seen this.... I cant remember now ? It wasn't long..... Do You want me to get his new number for you ?
Nov 18, 2013 14:14:51 GMT
Yes mate I am - how long did gary need to complete you 5 link work? Sorry fella, only just seen this.... I cant remember now ? It wasn't long..... Do You want me to get his new number for you ? Yes please Can't remember how much of a cage you had? Was it a full one or just the rear?
Nov 18, 2013 17:53:50 GMT
Sorry fella, only just seen this.... I cant remember now ? It wasn't long..... Do You want me to get his new number for you ? Yes please Can't remember how much of a cage you had? Was it a full one or just the rear? Its a full cage, 6 point bolt in, with Diagonal, rear stays modified to pick up on the Turrets rather than on the wheel arches. I`ll get Garys number for you and stick it in a PM
Nov 26, 2014 13:49:50 GMT
Crikey, a year has passed with no updates........ That's fatherhood for you I suppose.
I`ll do a proper update later, I was just trying to find it again !!!
I`m currently playing with 6-speed Gearboxes, New cast bellhousings, Air jacks and Fat arches ;o)
