Aug 31, 2007 22:39:17 GMT
Excellent work as ever, DeZmond.
I'd love to be as talented at this fabricating lark. Chopping stuff out is the fun bit, but I always hit the wall when it comes to putting it back again. Restecp.
The frame looks excellent my favourite amount of channelling too. What shape are you having the floor? On a mates car which was channelled slightly more than yours we fitted the floor level with the bottom of the body so it was infact lower than the chassis rails. It gave an extra 4" of legroom and is a lot comfier to drive than most channelled cars i've seen which have flat floors, and mean you have to drive with your legs horizontal like a westfield.
Matt
qwerty
Club RR Member Number: 52
Brilliant work!! Awesome to see it coming together
61stu
Sept 1, 2007 11:02:13 GMT
lovin ya work dude
Dez
Club RR Member Number: 34
Sept 2, 2007 18:40:48 GMT
The frame looks excellent my favourite amount of channelling too. What shape are you having the floor? On a mates car which was channelled slightly more than yours we fitted the floor level with the bottom of the body so it was infact lower than the chassis rails. It gave an extra 4" of legroom and is a lot comfier to drive than most channelled cars i've seen which have flat floors, and mean you have to drive with your legs horizontal like a westfield. Matt cheers man, I'm pretty happy with how the frames turned out, its exactly what I had envisioned. ive already considered your floor idea to get more space in there, but by the time theres the gearbox, propshaft, and K-member in there, theres pretty much no room between the rails to sit down into anyway. I may be able to kinda have a 'scollop' down into the floor a couple of inches deep (depending on K-member placement) to form the base of the seat, but thats about it. I actually find a legs straight seating position more comfortable as long as I have thigh support, as i've had knee trouble in the past from my bmx and mountain bike days. I wasn't able to drive my split bus very far at a time because the bent knees driving position gave me a lot of grief. so far though I have built this car around me, even though I'm 6'4", I do fit!
Last Edit: Sept 2, 2007 18:46:55 GMT by Dez
Sept 2, 2007 19:14:36 GMT
Crikey! Super talented at fabrication!
looking good
Tillio Race Prep and Spares Ltd
Oval racing Rollcage fabrication from £250.....Track car builds, engine conversions etc...
Dez
Sept 3, 2007 10:52:02 GMT
another update..... i got a little more done on saturday, first i sorted out getting the troublesome rear body X-member in at the right height. its pretty critical as its all that holds the back of the body up(at the moment), and if its not held at the right height the door gaps sag and the doors wont shut. but after a bit of messing about, i have this- then, i did a bit of mock-up work on it to check the locations and clearances of the major components. i slid the rear axle in, and the rear wheels and tyres on. they sit pretty much exactly where i wanted with it set up at ride height. then, i chucked a spare engine block in between the rails to see how the motor will sit, more or less. this bit wasnt too precise as the final motor isnt decided on yet, but as they're all about the same size it give me an approximation of ground clearance and the space i have for the rad. sunday saw a trip to the car boot, to see my guy there who specialises in second had engineering tools. i get all my taps/dies/drill bits/etc. off him, and he furnished me with a brand new, very good quality 13mm drill bit for the princely sum of a quid. this enabled me to drill out the seized in remains of the spring perch bolts i had to cut off to get the front end apart. a lot of drilling later they were out, and i could file up the holes in the beam and reassemble the front suspension with the new shackles, batwings and perch bolts. here it is, ready to be fitted-
Sept 3, 2007 12:46:26 GMT
thats look spot on with how the wheels sit and ride height.
Davenger
It's only metal
Club RR Member Number: 140
Sept 3, 2007 13:31:17 GMT
Dude, you put the Fab into fabrication
Sept 3, 2007 18:25:15 GMT
so far though I have built this car around me, even though I'm 6'4", I do fit! Thats the best thing to do. So many people build a killer looking car only for it to be uncomfortable and horrible to drive. Me and my dad went to look at steel 28 model A pickup that he fancied buying. It was really nicely built and the handling etc was brilliant. However the seat back tipped forwards, and after 10 mins test drive we both had stoops like the hunchback on notre dam. Matt
61stu
Sept 3, 2007 20:13:58 GMT
quality project mate, love it ;D
kram
Sept 3, 2007 20:25:58 GMT
I was trying to see were these bits over the rear crossmember were going to fit but now there in its such a simple way ,even though a massive amount of cuttin and welding , I'm building a 28/29 A pickup in a similar style as yours low n Zed frame....nice work ......keep the updates... another update..... I got a little more done on saturday, first I sorted out getting the troublesome rear body X-member in at the right height. its pretty critical as its all that holds the back of the body up(at the moment), and if its not held at the right height the door gaps sag and the doors wont shut. but after a bit of messing about, I have this-
79 Escort Van (Cossie Turbo'd) 70 MK1 Escort Wagon (Weld-a-thon) 88 Saff Cosworth (2WD) 54 Ford Pop (V8) 29 Ford A Pickup (V8 Project)
Dez
Sept 3, 2007 21:45:23 GMT
so far though I have built this car around me, even though I'm 6'4", I do fit! Thats the best thing to do. So many people build a killer looking car only for it to be uncomfortable and horrible to drive. Me and my dad went to look at steel 28 model A pickup that he fancied buying. It was really nicely built and the handling etc was brilliant. However the seat back tipped forwards, and after 10 mins test drive we both had stoops like the hunchback on notre dam. Matt nearly always the way with pickups though isn't it, you can barely chop or channel them, unless youre an amputee, or dwarfism runs in the family even coupes are like it to some extent, hence me choosing a sedan. plus, sedans look better my driving position is straight-legged so i sit far back, but the line of sight is in the centre of the windscreen so i shouldn't have to stoop/hunch to see out. to get it right though, the driving position involves a fairly long steering column as i almost sit in the back seat!!
Last Edit: Sept 3, 2007 21:49:56 GMT by Dez
Dez
Sept 3, 2007 21:46:34 GMT
I was trying to see were these bits over the rear crossmember were going to fit but now there in its such a simple way ,even though a massive amount of cuttin and welding , I'm building a 28/29 A pickup in a similar style as yours low n Zed frame....nice work ......keep the updates... another update..... I got a little more done on saturday, first I sorted out getting the troublesome rear body X-member in at the right height. its pretty critical as its all that holds the back of the body up(at the moment), and if its not held at the right height the door gaps sag and the doors wont shut. but after a bit of messing about, I have this- yeah, it was basically a lot of work to do something very clean/simple!! got any pics of your build?
kram
Sept 6, 2007 10:41:11 GMT
Yea got some pics but cant seem to post em ?.....My Pickup is chopped 4inches n also channeled 4 inches, n still have headroom...... got any pics of your build?
street
6.2 ft/lbs of talk
Sept 6, 2007 10:46:43 GMT
That is going to look jawdropping! Keep the great work going, it's inspirational! I'm going to take your pie-cutting method of bending box section and use it on a non-structural part of my project, because it looks ace the way you've done it!
qwerty
Sept 6, 2007 13:54:46 GMT
How do you source such things as the Beam axle? How much does that kinda thing cost?
Dez
Sept 6, 2007 16:42:58 GMT
That is going to look jawdropping! Keep the great work going, it's inspirational! I'm going to take your pie-cutting method of bending box section and use it on a non-structural part of my project, because it looks ace the way you've done it! its definately the way to do it, should suit your car nicely too
Dez
Sept 6, 2007 17:03:22 GMT
How do you source such things as the Beam axle? How much does that kinda thing cost? welll, as you know, i deliberately bought a more or less complete car to cut down the amount of parts sourcing i had to do. but, the bits are available from dukesville, originals, pop browns etc.- at a price..... if you're gunna build one, buy a big job lot of bits from the states,and ship em in yourself from speedway, TCI, etc. even if/when you get clobbered by tax, its a lot cheaper! some original parts are available, some cheap some expensive. truck brakes like ive used are loads cheaper than '40 car ones, same with spindles, and the work/look just as good. youll easy loose £250 in a set of '40 brakes, and £150 for splindles and arms, whereas i paid £100 for my complete truck front beam, brakes, spindles, etc. with new wheel cyls, shoes and bearings! stock undropped model A beams without any ancillary parts are cheap- usually about £30-40, but set up conventionally means a high car, if you use one you need to go spring-behind. a 4" dropped one like the Vintage Chassis Works one i have is about £200. stock model A wishbones are cheap, but are useless for anything other than a T-modified, they're too short. long ones such as '38-'40 ford fetch a couple of hundred in good nick, just cos they're 6" longer. some prices of other parts- if you go for batwings and hairpins instead fo wishbones, which a lot of people do cos long ones are cheap and they're new so don't need refurbing- batwings £55 hairpins £90ish new kingpins £35 spring perches £30 shackles £17 new reverse eye spring £100 or so. £40 for a repro front X-member 36-40 spindles £150ish new trackrods ends or heims £17 each steering arm £20 basically, don't expect any change from £1000 to put together a decent front end, unless you get some serious autojumble bargains. thats a plain mild steel setup, if youre into your bling and want chrome or stainless, double or even triple that price.
psycho83
East of England
Rhythm and Booze
Man, I can't wait to see this car out and about in Ipswich! looks like it's going to be awesome! a fellow ipswich rodder, are there many of us about? I only know of 3 or 4
