luckygti
I need to try harder!
Aug 26, 2009 21:28:11 GMT
I read it all, but to be totally honest, there's a fair bit you explain that I don't understand; I just take your word for it. I've just read through the whole thing and I get most of it but a bit like ^^ amazing work though, think I might have to pop over and be nosy!
remmoc
Aug 26, 2009 21:30:53 GMT
Theres a company near where i live that can do this sort of rad work , proper old school skills
Sept 10, 2009 22:30:56 GMT
i know its an old thread but curse word it lol this is cool!!
Do you go Dick Turpin on a wed nights?
Lots of rods get down their.
nugget
Sept 17, 2009 18:36:49 GMT
Any progress on this Dez? Love this aul wagon!
Dez
Club RR Member Number: 34
Oct 19, 2009 23:17:20 GMT
a fella could get a big head with all these props you know ile take em in a slightly embarrassed but secretly quite proud way. anyways, youd all best get ready for some serious updates over the next few months. ive just spent the last 2 weeks getting 'dug in' for the winter, re-arranging my entire workshop around being able to work on this thing on all those cold dark evenings. a bit of paint on the walls, wire up a couple more lights, throw up a couple more shelves and a new dedicated bench, and I think itll be rolling/driving by the time it gets warm enough to not need 3 hoodys anymore....... theres aready been some major progress on rear suspension (cos I don't think ive posted anything on that yet) and the steering (cos I don't think ive mentioned that either). not to mention ive also organised the machine work I needed doing, which will be done when my mate is on nightshift and his boss isnt looking over the next few weeks. the bits I need are the bearing spacers for the front hubs, the spacers/bushings for the wishbone spring mounts, and turning down some steering arm ends into tapered bungs to weld into my new steering arms and accept the trackrod ends. will update as soon as its all done in the metal
Last Edit: Oct 19, 2009 23:19:45 GMT by Dez
Glad to hear there'll be some updates Dez, i've been waiting very patiently!
Mike
East Midlands
Looking forward to the updates!
Dez
Oct 21, 2009 21:49:11 GMT
I started writing this a while ago, but really don't feel in the mood now so its probably a load of balderdash. might rewrite it later, only posting it so I don't loose what ive written........ this time, ive been knuckling down to the task of some pretty hardcore fabrication, no welding this time, its all marking, cutting, grinding, filing, drilling and holesawing. but being able to make something accurately that functions correctly and is asthetically pleasing is a skill all in itself. first, I turned my attention to the small matter of attaching my rear axle to the chassis. ive had a plan in my head of how I was going to do this for a long time now, and I actually made the first bracket about 6 months ago, and have done a bit on the others here and there, but I finished them all off this week by making the last 2. the suspension itself will be my take on a triangulated 4-link. the bottom 2 bars will be in the conventional place, but the top 2 will be replaced by what is basically a great big Y shaped wishbone. I also bought the correct bolts a while back too, and a bloody huge 3/4" rose (or heim depending on where your from)joint for the central main pivot. to recap, the axle is an early example of the ubiquitous ford 9" from a '59 galaxie. so the axle tubes are the more or less standard size of 3"OD. I wanted my bracket to fully wrap the tube, like a 'ring', I doubt they're much stronger than a conventional half-round bracket, but they definately look better- I think they look really cool but more importantly it makes them easier to position before welding them on, as you can just slide em around and they don't fall off. they are all made out of 1/4" plate, with a 3" hole boshed through, and a 1/2" hole that sits 4.5" away, C-C. in between this there is then another hole, which will have a 1" thickwall tube welded between each pair of brackets, to stiffen them. img.photobucket.com/albums/v617/dezaster/A sedan/DSC00411-1.jpg[/IMG] heres a little insight into how I make all this stuff- no fancy production techniques, just old school fab work. they're all cut by hand with a grinder with 1mm discs, I make one as a 'master', all marked out normally, then each successive one is roughed out a fraction larger from the sheet of 1/4" plate, then tackwelded to the master, and that used as a guide for grinding down and drilling/holesawing the holes. it means they're definatley all the same this way. just make sure you get that first one right!! heres a shot of one being made by this method in the drill press- the master tacked on top acts as a guide for cutting the lower one- img.photobucket.com/albums/v617/dezaster/A sedan/DSC00404.jpg[/IMG] one little aside ile mention, I quite often see holecutters getting a slagging on various forums for being useless. this is purely operator error, the only useless thing is the person who hasnt read the instructions. I love holecutters and use them LOADS, and never have problems. look at the pic above and notice how well its all clamped down, and the size of the drill press (its 5 foot tall) plus all the oil everywhere- all key to success with holecutters. these are cheap ones too, mostly screwfix (except for the sizes they don't stock), and they last just as long as the expensive branded ones. as for the brackets, you will notice that I have made 2 'doubles' and 4 singles. this is because the doubles do just that, they double up and hold both the top and bottom links. the bottom links will go in line with the chassis rails, the tops will go just inboard. it will all look like this when assembled (mocked up on some 3" exhaust pipe to illustrate). img.photobucket.com/albums/v617/dezaster/A sedan/DSC00416.jpg[/IMG] the bushings are standard aftermaket fare, basically inner and outer steel tubes with polybushes between. I think they're 2"OD, 1/2" hole, 1-1/2" wide. they will weld onto the ends of the wishbone/lower link tubes, for a small amount of vibration damping, then the other ends will be on heims, which will be adjustable, but are all-metal so don't damp vibration. next job here is to half all the brackets, slip them over the axle, then tack them back together. then I can make the brackets for the front of the lower links, and the lower links themselves. more on that soon. there will be a steering related update next though.....
Last Edit: Jun 12, 2011 17:09:30 GMT by Dez
Davenger
It's only metal
Club RR Member Number: 140
Oct 21, 2009 22:02:56 GMT
You don't muck about do you mate. Looking good
Oct 21, 2009 22:33:47 GMT
That last picture looks pure class.
Dez
Oct 21, 2009 23:25:51 GMT
You don't muck about do you mate. Looking good only in the large spells between me working on this A.F.O.D, in the words of B.T.O., you aint seen nothin' yet- theres WAY cooler stuff coming than this. i like to think bracketry is my speciality........
Dez
Oct 21, 2009 23:47:28 GMT
so I was talking about steering. this is the bit where I confirm ive totally lost the plot......... as a few of you will know, theres a lot of choice in off the shelf steering arms for ford I-beam applications. all the american parts catalogs (speedway et al) have many paged dedicated to the many bolt-on solutions for the condundrum of connecting the wheels together by the medium of a trackrod (not a tie rod, I'm not an american), with various cast-steel arms of different drops and length all available off the shelf, plus top steering arms for cowl steer applications like I'm running too. so this is the bit where I just pick up credit card, and make the call- 'hello, speedway motors, about the steering armz'. erm, no. back to reality, where I talk lots more about cutting up bits of metal with a grinder, then drilling holes in it. the first arm I will cover is the steering box drop arm. this is the sensible one. you wait til I show you the 2 lower steering arms whittled out of a 1" thick tractor wheel weight luckily, I didnt have the same idea as the last guy who tried to make a cowl steer setup for my car. check this bad boy out- img.photobucket.com/albums/v617/dezaster/A sedan/DSC00405.jpg[/IMG] if that don't make your ringpiece pucker, nothing will. cutting and welding (when you quite obviously cant weld for sh1t) on a piece of metal less than 1" diameter, when its all that connects your steering wheel to your wheels. safe. in this pic is the old 'death-arm' with my new super-safe properly fabbed steering arm above it. only you cant see it cos its still hiding inside that slab of 20mm plate thats masquerading as a home-made axle stand a friend gave me. img.photobucket.com/albums/v617/dezaster/A sedan/DSC00406.jpg[/IMG] said slab with axle stand attachment removed and surface ground back ready to spray and mark up. img.photobucket.com/albums/v617/dezaster/A sedan/DSC00410.jpg[/IMG] now painted white with some scribble on it- img.photobucket.com/albums/v617/dezaster/A sedan/DSC00413.jpg[/IMG] you can see, that the basic plan was to cut the splined end off the 'death-arm', grind it down so its more or less round, then cut a hole into the top of the new arm, drop it in, put a healthy chamfer on both sides, then weld all the way round on both sides, for some super-strength. previous calculations when I mounted the steering box determined the arm needed to be 5" long C-C, so thats what I made it, making the 'bulge' on the skinny end 1-1/2" diameter so I had plenty of meat to drill it for a track rod end. I made the main length of it 1" wide, and its obviously 20mm thick. it will all be rounded off and smoothed once completed, so it looks like a stock fitment cast steel arm. so all this hard work will go unnoticed. hurrah! this is as far as I got before I got told to stop making grinding noises as the landlords daughters baby was trying to make enough noise to drown them out. img.photobucket.com/albums/v617/dezaster/A sedan/DSC00417.jpg[/IMG] so I thought it best to finish grinding it up tomorrow........ the splined bit you can see there is actually 3mm wider than the arm, which will mean I can leave a good weld on the back of it that doesnt need ot be ground down, so itll be nice and strong. it has just occured to me, I don't think I mentioned actually mounting the steering box, or how I figured out where it will go. ile read back, see if I did, and if not write something up about that too.
Last Edit: Jun 12, 2011 17:11:11 GMT by Dez
epic skills once again, cant wait to see what else you fab up
2001 Micra 998 - Daily
1986 Mini Mayfair 998 - Former Daily - Garaged
Oct 22, 2009 11:16:46 GMT
Loving it, just seeing this car allows me to dream of what I'd do if I had the money and the skills......
There is no such thing as a curse word car just overstretched expectations................. Herald 10/10 Gasser 10/10 Total score 20/10
Dez
Oct 22, 2009 22:36:36 GMT
in this continuing saga set over many years and an indeterminate amount of installments that appear at haphazard intervals, I invariably forget things. one of those things is why I put my steering box were it is. so gather round one and all, make yourselves comfortable, and listen to a tale of steering geometry, bumpsteer, and good old fashioned fab + welding. in previous installments, ive described how I made my actual steering column (p.9), and the steering box drop-arm (pittman arm) in the above post. I couldnt have done them without knowing where the steering box mounts, or indeed if the steering box was at all suitable for my application. basically, for a steering box to work for cowl steer on a RHD car, when you turn the steering wheel right it needs to push the arm forwards, and when you turn left it needs to pull back. if it goes the other way, your steering will be reversed, with hilarious consequences. as luck would have it, the one I got goes the right way. the steering box on my car is from a '68-'72 VW baywindow van. but, it has had the steering output shaft lengthened by about 3", so it sticks out of the cowl enough for it not to catch anything (a common problem with cowl steer is most steering boxes have too short an output shaft to work, so you end up with crazy shaped pittman arms that curve out to clear the body). img.photobucket.com/albums/v617/dezaster/A sedan/DSC00432.jpg[/IMG] its been properly machined and double pegged (no welds at all), and is an excellently made piece of kit, the only decently engineered bit I got with the car, and certainly not the work of the person who did everything else on it. the bracket holding it on was a inadiquate, innaccurate, flexy pile of sh!t as you expect, so I binned that, and proceeded to make this- img.photobucket.com/albums/v617/dezaster/A sedan/DSC00430.jpg[/IMG] its just a bit 'o 2x4 same as the chassis rails are made from, with 2 holesaw holes in it (they're a different size each side cos of the boss for the shaft on the side you cant see), its got thickwall crush tubes welded in for the mounting bolts, then the bolts were sized up to m12 from m10, as this lot needs to be bloody solid, but mostly cos I had the right size tube to sleeve it for m12s but not m10s but, the clever buggers amongst you will notice that I couldnt actually have done that until after id mounted it, as I wouldnt know where the crush tubes needed to be welded in as I wouldnt know the angle the steering column would sit at, as its determined by the dash too. ive still got to notch the side and add in a 4th tube for the last mount at the front there, next time I take it off. I cut the piece of box slightly over-length at the bottom at this point, as although thatll hold it on nicely, it still don't tell me where it goes. I have to say, this following part has been one of the most stressful parts of the builds, cos what the finished product drives like depends on this bit more than any other part. basically, its all about parallelograms. if you don't have parallelograms, the links will have different paths which will conflict, creating bumpsteer. you can get away with them being close but not quite, but the further out they are, the more bumpsteer you will get.(if you don't know what this is, its as simple as the name sounds- when you hit a bump, the car wants to steer!) firstly, you need to make sure your wishbones are horizontal at ride height, but thats all covered in the 'making the suspension' bit. then your draglink needs to be parallel to your wishbone, so also horizontal. this bit isnt usually too hard to achive. but then, they also need to be as close as possible to being the same operational length. in other words, the pivot-to-pivot length of the draglink should be the same as the distance from the rear wishbone pivot to the centreline of the axle. this is often quite hard to achive, and my draglink is actually about 2-1/2" longer as I cant physically push my steering box any further forward- the gap between the front of the steering box and the back corner of the right hand head is only 1/4"!!(look in the above pic) but over a length of 36.5" for the wishbone, its only a 7% variation, so I'm ok with that. this pics explains, I hope- the white rod is where the draglink will run, more or less. as you can see, it and the wishbone sit more or less parallel- img.photobucket.com/albums/v617/dezaster/A sedan/DSC00436.jpg[/IMG] on top of that, your steering box drop arm has to be vertical when its at the centre of its travel (i.e. 'straight ahead' position) or you car will turn further one way that the other. ditto the spindle arm needs to sit perpendicular at this point, for the same reason. so, in essence, where your steering box goes is determined by this bolt- img.photobucket.com/albums/v617/dezaster/A sedan/DSC00431.jpg[/IMG] as this is where the steering arm bolts on(and the one on the other side of the kingpin). the height of it is determined by your wheel radius, so, in the simplest terms, your wheel and tyre choice determine where your steering box goes!! (the height of it anyway) as it will be a line horizontal to this, plus the length of your pittman arm. as for pittman arm/spindle steering arm lengths, it can start to get real messy if they're a different length, so I played it safe, checked how long most aftermarket spindle arms were, which is 5" operational length (but, remember the operational length is measured from the centre of the kingpin, not the backplate, as this is where it pivots). I also got a mate to measure how long the stock arm on a bay was, and it was either 4.5" or 5.5" I think. so I played it safe and made both 5" operational length. so now I knew where it need to be in terms of height. but then, for you to not get the dreaded bumpsteer, you also have to take into account the suspension articulation, as this can create feedback through the suspension too when it moves from side to side, so the draglink has to also be parallel to the wishbone side to side too. like so- lastly, an inside the footwell shot- itll give me a nice flat back to the footwell, and theres just room for 3 pedals and my size 10s in there!! I'm gunna have to get very creative with the linkages for the pedals though, as the master cyls cant go anywhere on this side of the car. I got it all figured though img.photobucket.com/albums/v617/dezaster/A sedan/DSC00428.jpg[/IMG] its also reminded my I havent posted up the making of my rather complex gearbox crossmember yet either.... thats one for another day.
Last Edit: Jun 12, 2011 17:13:07 GMT by Dez
Davenger
It's only metal
Oct 22, 2009 22:44:54 GMT
Plenty of room in there for your period pedal rubbers, lol
Great write up Dez, can´t believe how bad that deathtrap arm was, you´d think self preservation should be motivation enough to weld it up properly FFS:
Dez
Plenty of room in there for your period pedal rubbers, lol they're DEFINATELY going on there mate, was only sizing them up the other day as part of designing the brake system ;D
Dez
Great write up Dez, can´t believe how bad that deathtrap arm was, you´d think self preservation should be motivation enough to weld it up properly FFS: natural selection my point was, you shouldnt cut and weld on components like that at all really, no matter how good your welding is. it should be made how ive made the new one, as youre not relying on a small amount of weld to take all the forces then. youve actually just reminded me about the old spindle arm, this was made from round bar about 8-10mm looped around with a trackrod taper cut off something else welded to it. you could bend it by hand!!
Dez
Oct 24, 2009 19:32:52 GMT
another small update. more brackets!! I made these brackets a while ago, another bit id forgotten about. remember these from pg. 13? well, now the grille shell was on I thought it about time I fitted them too to get the whole frontal aspect of the car together. I could go into the whys and wherefores of headlight placement, and how hard it is to get it right, but most of it is just opinion. suffice to say, mount em too high or too low and it looks stupid. too far fore or aft, likewise. I like to line up the headlamp rim/bowl join line with the striaght back edge of the grille shell, as to me this looks 'right' as theres then a straight line across the car. you also gotta make sure the tyres don't hit them on full lock too. so to get the placement right it meant more fabbed brackets. plus they look miles better than off the shelf stuff. ive taken what is essentially a couple of very simple brackets to hold the headlights on, but theve been given the dez twist- not a straight edge on them! they curve, sweep and fillet down to the chassis, all welds are smoothed off, and they hide the bolt underneath. overall, quite asthetically pleasing I think- img.photobucket.com/albums/v617/dezaster/A sedan/DSC00421.jpg[/IMG] img.photobucket.com/albums/v617/dezaster/A sedan/DSC00422.jpg[/IMG] ive also repaired and modified the headlamp shells, as they had some cracks and extra holes drilled in them, then I had to adapt them to take the adjustment/mounting mechs off some cheap 7" aftermarket things, as the stock ones were heavily corroded and most of the bits were missing. they just need converting to take modern bulbs/reflectors now, as I want the lights to be decent, and I don't think you can get this type of bulb anymore anyway. img.photobucket.com/albums/v617/dezaster/A sedan/DSC00423.jpg[/IMG] but on the sh!te side of things, youll notice theres only one headlight fitted. that cos ive somehow managed to break one, even though they immersed in bubble wrap in their own seperate box. ballsticks. so, if anyone had a lucas XD 714 B lens, they're a 8" catseye domed glass as fitted to pre war ford tens and austin 10s, let me know.
Last Edit: Jun 12, 2011 17:15:10 GMT by Dez
