Aug 30, 2007 19:19:06 GMT
Took even more of it apart today... including removing the dash. I wanted to remove the sound deadening from behind it, which turned out to be a bit more involved than I first thought! What I dug out weighed over 5kgs though... Also removed all the radio wiring from behind it as well. The heater's staying for the moment though. Zinc primered more of the bare metal: Got a fair amount of welding to do now... loads of holes in the floor. Adam
Ben
Aug 30, 2007 19:25:53 GMT
looks brilliant mate. bookmarked your website too
Aug 30, 2007 21:40:27 GMT
A few more pictures. How she is at the moment: Sorgot to say I removed the door cars as well, but kept the pockets as the hold the electric window switches (it'll all be going when we get some Polycarb windows). All the curse word that came out from behind the dash: Adam
BiAS
Insert witty comment here
Club RR Member Number: 147
Superb effort dude, weight loss is where its at if you've got a small engine, power to weight ftw every time. Don't reckon that patch would be too bad to make. Do the welding on the floor first to get yourself in the mood for it. And when you attempt it, make it out of cereal box first then transfer it onto tin.
(car+wheels)-rideheight=WIN
VWDan
VW Jetta MK1, VW Caravelle 1.9TD, Audi A6 Tdi Avant
Good progress Adam, impressive.
If only everything in life was as cool as a retro VW racer.
Thanks guys Why does nowhere except Peugeot sell thrust bearings on their own? Peugeot want about the same amount as a whole clutch kit from most places for just a thrust bearing! Got a few more places to try this morning though... hopefully one of those will be able to get me one. Adam
gearoil
Projectless...
Aug 31, 2007 10:48:59 GMT
Good skillz there, where do you plan on competing with it? That pillar looks nasty, finding a dead 205 to cut a panel out of shouldnt be too hard. Let us see more...!!! Cheers
Aug 31, 2007 17:49:25 GMT
Removed all the electric windows today... thats about 10kgs out of each door if you include the windows themselves.
Serious weight loss!
Adam
Aug 31, 2007 18:14:28 GMT
Oi , Adam.... you are another who does not pisss about ehh ?
Good progress.
J.P
I like to eat ice cream and I really enjoy a nice pair of slacks.
Aug 31, 2007 18:35:37 GMT
Looking Good Man. Polycarb ftw.
Aug 31, 2007 18:53:56 GMT
Oi , Adam.... you are another who does not pisss about ehh ? Good progress. If i curse word about i wouldnt get anything done... i go back to school on Sunday and that's 6 days a week!
qwerty
Club RR Member Number: 52
Awesome progress!! Brilliant car. Wish my dad shared my enthusiasm.
Get the metal inner door panels cut out and the metal inner panel of the bootlid that sheds a lot of weight.
Matt
Sept 1, 2007 21:58:01 GMT
Was gonna do that, cut out the door inners and replace them with a sheet of ali. Looks neater & lighter.
New thrust bearing arrived in the post this morning which means i can get the gearbox back on soon!
Adam
Sept 8, 2007 17:45:09 GMT
Took the fuel tank and windscreen out today so I can can get welding tomorrow. Fuel tank came out with no problems.... took about 15 litres out of it as well! Windscreen went wrong... there was a nasty chip near the outside of the screen and when we pushed it cracked to the chip. BALLS. It came out fairly easily and in one piece past that, but now we need a new screen At least now I can get repairing the rust and holes!
J.P
Sept 8, 2007 18:37:13 GMT
How bad is the rust? Just small holes? Plenty of pics!
Sept 8, 2007 18:39:00 GMT
How bad is the rust? Just small holes? Plenty of pics! Yeh not a lot other than that pillar, just lots of holes had been drilled in the floor and not protected at all and have started go.
Sept 9, 2007 17:29:43 GMT
Welded up the majority of the holes in the floor.... but managed to break two grinder trying to grind them flat! Balls.
I also managed to change the track rod end with the aid of a beefy dad and a blow torch. This means it's starting to go back together again! (almost....).
And I found out that 1.6 GTi discs won't fit, so I'll have to find a pair of 1.9 GTi ones. More expense!
Sept 16, 2007 17:17:27 GMT
Got the gearbox back in today.... one less large object in the garage!
Pics soon.
Sept 16, 2007 17:22:10 GMT
nice peugoet
