markgtt
Mini vauxhall powered
May 11, 2007 20:16:20 GMT
Stiff
'kin 'ell
May 11, 2007 20:21:13 GMT
Very nice!! Lots of work gone into that, bet she flys!
May 11, 2007 20:33:52 GMT
Hi Mark... you've worked hard on your car! Thats really nicely done.. engine looks like its gonna be quick! cheers for sharing with us!
markgtt
May 11, 2007 21:03:02 GMT
thanks guys, hoping for some good figures when it goes on the rollers
May 11, 2007 21:43:54 GMT
Thats really smart
[/color][/b] [/CENTER]
tigran
In rust we trust. Amen.
Club RR Member Number: 142
Clubman GT turbo.tigran
@tigran
Club Retro Rides Member 142
May 11, 2007 22:41:13 GMT
Sweet looking car - what are the engine specs, out of curiosity?
Mark
May 11, 2007 22:44:48 GMT
Wow - that front fits really well, they can be a right nightmare!
Lovely car!
May 11, 2007 22:52:18 GMT
If i was to go anywhere near getting a mini project, it would be like that (hopefully). beautiful, and looks like a pile of fun!
hitman
May 11, 2007 23:02:53 GMT
welcome mate. thats a clean looking motor + very
jdmini
May 11, 2007 23:09:50 GMT
looks really good...are those tyres road legal?
markgtt
Sweet looking car - what are the engine specs, out of curiosity? Cheers again for the comments! the engine is originally from a 1275 metro, now a 1293. med Forced Induction head - 36.0 and 32.0 valves - reshaped and modified etc. +20 tho pistons dished 10cc 1.3.1 rockers reground crank i think the cam is the metro 1275 (that will be checked this winter and probably changed) T3 turbo maestro turbo carb 10 psi actuator + MBC straight through exhaust etc. mappable ignition - coil pack from a ford, edis system and meagjolt ecu - laptop etc. front mounted metro rad. alloy intercooler. lightened and balanced flywheel AP clutch and rally diaphragm jkd straight cut drops x pin diff etc there is still some work to do to the exhaust manifold and turbo elbow.. also fitted Gaz adjustable shocks and adjustable ride height, all competition running gear so i can set the camber etc. AP 4 pots etc. fiberglass front end, carbon roof , fiberglass boot and rear valance, stripped the interior and fitted a full 6 point cage, polly carb windows. tyres are road legal Yokohama Advan A048's the front end was a right curse word to fit.. took me ages!! but really happy with the finish. will mostly be testing and making adjustments on it this year.
welcome very nice , you've put some hard graft into that
Clubman GT turbo.BenzBoy
@benzboy
Club Retro Rides Member 7
Wow, that's fantastic. I really like Clubby's, and I really like turbos. Perfect!
Very nice. How envious am I of that unrivalled engine access?!
Mark
May 12, 2007 12:40:31 GMT
Out of interest how do you have it mounted at the front? (the front end that is ;D )
markgtt
May 12, 2007 14:39:11 GMT
Out of interest how do you have it mounted at the front? (the front end that is ;D ) hinges at the bottom / front, to make it flip, over center clips in the inner wing, and bonnet pins at the back... all very tight to get a good fit.
