if you check back through the pages, you will see that ECU i bought many moons ago off ebay for a few pence......i had my doubts as to whether it would work, well, i plugged it in today and had a looky......... turns out it does, i ran a diagnostics test on everything and its all fine! (apart from the fuel pump but thats no worry tbh) anyway, the rest of the wiring is doubtful, but at least i have the main worry out the way
ezzysi
Sept 27, 2008 21:18:19 GMT
Just sat and read this from page 1..... superb dedication, i'd have got bored and given up ages ago. Any updates??
1991 Mk2 Golf Gti 8v 2005 Passat tdi (daily) 1971 Mk1 Escort 2004 Touran (her's)
J.P
I like to eat ice cream and I really enjoy a nice pair of slacks.
Sept 28, 2008 14:50:48 GMT
Didn't make it to Edition then? Any expected finishing dates?
Oct 19, 2008 11:09:13 GMT
no updates of late, not had the time, although it is pretty near completion (minus paint)
Oct 19, 2008 20:29:13 GMT
top work mate.
I too just sat and read all 19 pages!! Nicely done!!
Dec 26, 2008 20:06:29 GMT
little yule tide picture of things kind of happening. i've a week off at the start of january. expect a big update
Dec 27, 2008 14:01:28 GMT
wooot! cant wait.
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Dec 27, 2008 14:12:54 GMT
sweeeeetttttt this is gonna look ace !!
i did say there would be many a wheels in motion after christmas, and there kind of was, but nothing at all interesting that was worthy of a picture. since january i've: made myself a set of plugleads and finished all the plumbing and filled it with water making this: to go here: plumbed in the MAF and brake servo finished the wiring inside (Although it doesn't look it as a new task on the agenda is to make a dash for the carpc n stuff adapted this to my loom with the help of scaryoldcortina earlier today and then put a battery to the wiring and nothing exploded! let there be liiiiiiiiight (indicators in headlights a'la early beetle) oh, i painted these too, colour coded lips and canary yeller centres list to do in regards to getting the engine running are: fiddly petrol fitting big enough for the cosworth fuel pump (standard one is 6mm and the inlet to the cosworth one is at least 12mm! ;D) run through the diagnostics with the laptop to make sure all my sensors are working and injectors and coilpack, managed to leave it at home today. go to ford tomorrow to get me a new fuel filter.
TJM
Kinda New
Hi
Excellent project, having sold many top mounts, manufacturer normally states that the circlip is to be facing down instead of up as you have them fitted. May be worth checking?
Regards Tim
so you think they are in upside down? that could be possible! never thought about putting them in the other way around. but now you think about it it could be the truth.
think i;ll have to get my spring compressors back this weekend and have a look at them ;D
Mar 23, 2009 13:22:09 GMT
Yeah Latham as the guy says they are in upside down.
Got a set of spring compressers if you need to lend em
Mar 31, 2009 21:44:38 GMT
i've got some compressors mate,ignoring everything but the engine on a final hurdle to get the it running started the day by plugging stuff in a quick look at the ECU threw up 2 problems - TPS was wired in backward, my own fault as I didn't realise it wound the TPS to fully open as the throttle was fully closed, simple swapping of cables solved it. the water temperature is pretty high, using the wrong sensor, need to get another one from the scrapyard tomorrow and that's solved it. getting the right terminals for the cosworth fuel pump proved more than difficult, far too difficult for this sort of job, so I cut it up and soldered some bullets on...... which with a bit of heatshrink it worked out quite ok had to knock up a fitting for my fuel tank as the original one was about 4-6mm, and in order to stop the pump struggling to get fuel it needed to be at least 12mm...... I get paranoid about things, so I swapped the whole starter circuit - battery to starter, battery earth and engine to body earth to some 35mm^2 cable when I was testing my injectors, I managed to lose one of the caps in the inlet manifold, so I put henry to work, and got it out ;D
Davenger
It's only metal
Club RR Member Number: 140
The Silver EscortDavenger
@dminifreak
Club Retro Rides Member 140
Mar 31, 2009 22:02:52 GMT
Top Henry skillzzzzzzz
ignore my daft mother :lol: the starter doesn't seem to disengage so didn't want it running too long incase it burnt it out. so. that's that then.
Mike
East Midlands
Nice one!
my full tale of woe and betidement is as follows the only task holding me back was getting the fuel system in check. so that I did, couldn't get the fuel pump relay working, after a little looky at the wiring i'd clocked that the cable I shared from the relay next to it, wasn't the ignition live that I thought it was, but the switched side of the fanswitch, therefore instead of using the ignition as the feed, it was using the fanswitch ;D so I tested the fuel pump, it made a noise.....woo.... at least that works. filled it up with fuel this is when I started getting a bit scared, mixing fuel with electrical things i'd manufactured with my own hands scared me lots ;D got a bit of water just in case, it wouldn't have done curse word in hindsight, as you're meant to use powder or Co2 or something powered it up, instant spraying noise coming from the back, ignition off, checked under the back, it looked like those fibre washers i'd used weren't for petrol, oh well. popped to halfords got some nitrile ones that are holding up well fired it up again, could hear the fuel running down the lines, into the henginz, fuel pressure gauge rose nicely to about 2.5bar, I set it to 3 which dropped to 2.7 under cranking, which is what the ECU is set to.
J.P
Awesome, the end is in sight!
easy JP, yeah, it is.......you going to make it over to edition? plan is to 'lose' the keys somewhere in the show field with the rest of F6 ;D
good meeting you at UD BTW, you lot made my night with your general idiocy ;D
had another quick day on it today, my original TPS wasn't reading 'straight' in that the rate of change was all over place, when moving the throttle at a linear rate, the software was reading maybe 50% in the first actual 10% of travel, then slowed down, kind of like a hyperbolic sort of response (oh get me ;D ) anyway, after scouring the scrapyards high and low for as many zetec TPS's as i could lay my hands on (3, there are quite a few more!) plugged them into the ECU and messed with them, i found one that worked perfectly like what it should do. the stage after that required a vast supply of chemical metal, and a bastardisation of an old GSXR one to make the new TPS fit the bodies then a quick little task i had to do was to remove my the uppers of my seats.......... you'll see tomorrow night the reason for this
