I must not poke crusty bits
I poked....................
curse word
My day in pictures
I waxoiled the chassis rail and then noticed a bit of waxoil oozing out of a scabby bit on the chassis rail - well I couldn't leave it like that!!!
I'd hit it hard with a zip wheel when I was cleaning up the underside before painting and underseal and it didn't turn to dust but it obviously wasn't as sound as I thought
Chop chop
Glad I did - had to go a fair way over till I got to good steel
Grind grind - shiney steel
I'd had me cornflakes so the box came in handy - make a card template
Transfer to 1.5 mm steel
Cut, sand, hammer and splash a bit of weld thro primer on it
Same with the chassis rail that remained
Had a few hard drive failures over the years - recently liberated a few magnets out of the dead ones - make great fixings for butt welding - even better when you can find more than one of them - bloody mini in the garage seems to have eaten them all
Don't try to weld near one does weird sh!t to the arc!!
I know it looks a bit "gappy" but with multiple curves I find it easier to weld it in where it touches and then go round beating it into the shape that closes up the gaps - works well with chassis sections - not so well with bodywork!!!
Yes it did catch fire - but I was ready for it - I knew that the wax oil would flame up quite nicely
First piece in
Grind it back
Cornflake box and scissors I have plenty so knock the next bit up (holes are for a few puddle welds - spot welds with a MIG) My Portamig was appreciating the break as it's not been on power 5 out of 12 for a while - minis don't like anything more than 15 amps
Splash a bit of weld thro on it
Hit it with the sparkly stick
Upside down welding - yeah that's my strong point - NOT
Grind it back (just the weld so as not to thin the metal)
Bit of Red (Pink) Oxide - I remembered to drill a new drain hole
Am I happy with that......
Well a blind man on a galloping horse would be so
Slap some chassis black on it then
There I did it I posted pics of my not so invisible repair and "functional" welding - who'd have thunk it!!!
Subframe can go back up tommorrow
Following day still with burns from upside down welding so I thought I'd do some other stuff which had to be done
Sneaked out while Lisa was in the bath to finish painting the Diff........
Sorry No pics but it's black and pumpkin shaped - shouldn't be too hard to visualise
