Aug 13, 2006 19:16:26 GMT
Just get convuluted hose from a lock hose company - look in yellow pages and buy cash at the factory door, everythings a couple of quid that way Oil will emulsify if the car is used only for short journeys, so check thats not it be fore you panic. Flush the cooling system if it makes you feel better but one shouldn't be getting into the other unless you have still got a gone head gasket or a cracked head or something. Compression test it and see what that tells you. No idea of the cylinder pressures on the Oxford (I'm guessing like 140 PSI is right on them) but make sure its all in about 10% or so and your motor is healthy. 20% is OK.
Aug 13, 2006 22:28:30 GMT
Lowered, whitewalls (flaps for cheapness), paint the wheels (red would work) but keep the trims on and fit black/silver 'plates (but tucked right up under the bumper on the front) and that's one hell of a ride!
I like it! ;D
Aug 14, 2006 15:01:35 GMT
The numberplates are next on my wish list. Standard yellow and white.. what were they thinking?? They are pretty new too by the looks of it.
I'm hoping to get a set of donor steel wheels, have them shotblasted and then resprayed/powdercoated. I was thinking just plain wheel silver, but red has got me thinking..
I have used the car for long journeys, Stoke to Birmingham and back, 120 miles and so far ive driven 220 miles. The oil was fine on the dipstick but sludgy under the filler cap when I first got the car. Theres no sludge at the top end now, but the dipsticks covered in grey oil. One thought I had was that the engine oil could be the ORIGINAL oil that was in the engine when the engines donor car was parked up 20+ years ago. The guy took the engine from a rotted out scrapper and plonked it in this car and sold it to me. Doesnt mean he changed the oil, if the oil that was in the engine when he took it out, its atleast 20 years old, possibly more.
When I get the chance ill fill the engine with diesel and run it at idle to flush it all out, replace with fresh oil and get the rad reconditioned, its looking pretty damn manky as it is and go from there. The engine really does run sweetly at the moment so I'm hoping its nothing like a cracked head. I'm not too stressed over it as they are easy enough to swap and I know someone thats selling an unleaded head so I could plonk that on. Good chance to polish and port it too! Ill have to blag a compression tester from my dad next time I'm down too.
Another thought... grey oil= breaking up big end bearings??
1987 Maestro 1.6 HL perkins diesel conversion 1986 Audi 100 Avant 1800cc on LPG 1979 Allegro Series 2 special 4 door 1500cc with vynil roof. IN BITS. HERITAGE ISSUES.
Seth
Aug 14, 2006 21:42:59 GMT
My Oxford would always be sludgy/white mayonnaisey in the filler cap every winter. Just condensation and nothing that could be done about it. Never seemed to bother the engine. Sounds like you need to change the oil asap so at least you know where you're starting from Might be worth doing the gearbox (it uses engine oil) and diff (EP90) too.
Aug 17, 2006 10:38:08 GMT
when i get some spare time ill scan the pages with the greasing locations for u, unfortunatley i will be needing the manual for when i find a good front wing and other repair panels!!!! altho I'm very tempted with throwing a td in this one, as its an estate, and a bit heavier!
2006 Audi A3 2003 Fusion 2 looking for a project....
Seth
Aug 17, 2006 11:26:53 GMT
There shouldn't be too many grease points on a 63 Oxford. Definitely 3 each side for the kingpin/fulcrum pin on the front suspension, one on the handbrake cable and possibly the propshaft U/Js. On earlier cars all the steering balljoints had them but by this date they should eb sealed ones. Worth checking in case an older one has been fitted as a replacement at some point. I'd have thought a Marina top hose would be fine but not sure about bottom. The turn up on E-bay quite often though. If the number plate is on the original bracket you can tuck it under the bumper a bit by simply taking the bracket off the bumper and reversing it.
Aug 17, 2006 11:49:58 GMT
Ive got my eyes on a couple of bottom hoses on ebay, so I should get lucky out of the two. Ive been working funny hours this week, and I'm away this weekend so I havent beenable to get to the garage where the Oxfords kept to have a tinker Its very frustrating!!! I just want get cracked on and do the jobs that need doing. I just wanna drive it! Havent felt this way about an old motor for aaages.
The number plate bracket is some horrible welded bodged thing, so its not original I think. Should get a good pair soon though, to go with the new plates.
I'm still looking for doors, A guy on ebay is selling a set of 4 from a wolseley 16/60. two are meant to be mint, two have a patch of rust that needs welding the size of a 50 p in the bottom skins. He wants £50 and I cant see them until ive paid for them. Maybe I should hold out for a set of local doors I can have a proper look at.
Ive found a cambridge haynes manual in my collection so I shouldnt need a morris one, although one would be nice, just to get one in my hoarde of haynes books! For some reason the cambridge and the riley are together, and the wolseley and the morris are a seperate manual, weird.
You say you have an estate, any bits you need? My mate is stripping an estate for b*nger racing (its ok keep reading) and although most bits are trashed anyway, he said any parts that are left that he doesnt need I can have for free, want me to have a mooch for you?
*edit* yet another question. ive read that an MGB 5 bearing lump wont fit the original box without modification. Would an MBG 5 bearing lump with its correct 4 speed box bolt straight in instead? Id have lots of nice mg tuning goodies to play with then.
Last Edit: Aug 17, 2006 11:53:06 GMT by Lankytim
Seth
Aug 17, 2006 12:39:30 GMT
*edit* yet another question. ive read that an MGB 5 bearing lump wont fit the original box without modification. Would an MBG 5 bearing lump with its correct 4 speed box bolt straight in instead? Id have lots of nice mg tuning goodies to play with then. You'd have to swap the engine front plate with the one form your 1622 so you can bolt it up to the original engine mounts. Not sure how things would work out at the gearbox/prop end. But it must be do-able!
Aug 17, 2006 13:52:21 GMT
well i know for definate I'm going to need a drivers side front wing, possibly both parts of tailgate, i have an axle removed from a wolseley (tea bag) 16/60 which was slowly becoming one with where it was parked! i would maybe consider a swap of manuals as mine is the morris oxford-wolseley 15/60 16/60-mg magnette between 59 and 71 but mine is rather tatty!!! lol
lol, my austin manual is a minter, so i think ill keep hold of it The tailgate sections are rotten, and the wings are fibreglass. The whole car is pretty tender. Let me know if your interested.
Seth
I was talking to a bloke yesterday who has had a 5 bearing MGB engine with its O/D box in a Farina. Apparently the tunnel needs cutting to clear the box (and the carpets then don't fit quite right)and a couple of bits need chopping out of the gearbox crossmember too but it does bolt up. He was saying something along the lines of a Triumph 2000 prop was the one to go for with it too.
Ive got a couple of Triumph 2000 props, couple of everything Triumph 2000 actually!
I don't think ive got the stomach for chopping about the tunnel. ill probably balls it up and the car will stand in the garage until its broken banger raced or scrapped, none of which I want to happen!
Are there any 5 speed box converions? Ford sierra box possibly??
Seth
Yep, there is a conversion kit for the type 9 5 speed. There's a company that does them for MGAs and Bs (Hi-gear engineering I think?) so with the right mix of bits you can use what they make. I think the bellhousing alone is a couple of hundred quid though so it depends how deep your pockets are.
Pid363!
Madness is all in the mind!
Aug 22, 2006 20:10:51 GMT
I was talking to a bloke yesterday who has had a 5 bearing MGB engine with its O/D box in a Farina. Apparently the tunnel needs cutting to clear the box (and the carpets then don't fit quite right)and a couple of bits need chopping out of the gearbox crossmember too but it does bolt up. He was saying something along the lines of a Triumph 2000 prop was the one to go for with it too. That bloke was me hi seth. Ive just found this forum makes for good reading. The COOC is a must for any Farina owner. I'm well in to my bangers but also have had many Farinas on the road. Ive got a Magnette at the mo which has 1800 MGB engine and overdrive gear box, banjo diff , telescopic shocks all round but the shell is in a poor state. So ive gone and got another which will have 2.0 mgb 5speed box mgb axle when its done. Ive had Tr6 wheels on a couple of my A60's i think they look the part!!! Ive got a few friends who love there a60s one has a Cambridge estate with westy axle, turbo diesel engine overdrive box and a few other tricks hes a well smart bloke!! Ive also got a Friend who is about to put a 427 small bloke Chevy lump in a Riley 4/27!!!!!!!!
Stupid is as stupid does!
I didnt know all this was going on in the farina world...... I thought they all tootles about basically stock standard. What an eye opener. Know to any mint doors Pid?
Pid363!
No sorry been looking for some myself.
Aug 25, 2006 19:28:31 GMT
an easy & cheap power upgrade for the Oxord is fitting a manifold with four bolt carb from an 1800 b series Sherpa, Marina or MGB. Its that tiny carb that restricts the A60's and the bigger carb really opens it up without going for the 1800 conversion, i have done this on bangers and road cars & it really makes a difference !. You will of course have to make another downpipe ( i heated & bent an MGB one ) for the other manifold, or you can get an adaptor plate made for the original manifold so you can fit a four bolt carb - my mate has used a Maestro carb on his (!), just don't go daft with your selection of SU carb, one from an P4 Rover would be too big ;D ;D ! Another simple way to improve performance on Farinas is to make sure the points are set exactly right - this is vital on 1622's and makes the difference between a lively car and a sluggish one
Last Edit: Aug 25, 2006 19:29:41 GMT by sst468
wolseley 6/99, wolseley 6/110's, MK3 MG Magnette, Riley 4/72, Vanden Plas 3 Litre, Vanden Plas 4R, Riley 4/72 etc etc !! More down the yard !
Pid363!
Aug 25, 2006 19:56:00 GMT
You could always fit electronic ignition, plenty of kits around for mgbs but a cheaper way to do it is to fit a dizzy from a Austin metro late 80's a series one. You have to change the drive for an A60 one and best to lengthen the bottom of the dizzy where the drive sits. Ive got one in me road car and i know a couple of the banger boys who have the same.
les509
Compulsive collector
Sept 4, 2006 23:05:40 GMT
Nice Oxford Tim, I know so because it used to be mine up until earlier this year! I got the car as part of a two car deal ( I still have the Wolseley 16/60 that came with it), along with a good amount of spares.
Last Edit: Sept 4, 2006 23:07:56 GMT by les509
61 Jaguar Mk 10 67 Austin A60 Countryman 69 Morris 1300GT 77 Triumph 2500S 84 Mk2 Granada Ghia Est 86 BMW 635 CSi 87 BMW 635 CSi
Are you the guy who Scott was waiting for the log book off then?
Any spares you wanna get rid of??
