May 28, 2006 15:34:27 GMT
christ!!! you don't hang around do you mate??? its so clean, I really like it, what wheels and arches have you got goin on it???
CML Automotive Upholstery Llew Photography
Mike D
Club RR Member Number: 57
1994 Rover Mini Sprite 1275Mike D
@v8mike
Club Retro Rides Member 57
May 28, 2006 19:24:09 GMT
It is remarkably good compared to the others i looked at! Wheels going on are 6x12 superlights, arches are group 5 race. hopefully tomorrow will be as productive as i hope!! ;D
May 28, 2006 21:10:51 GMT
that is one clean mini! i have a mark1 I'm building, would put it on here if i knew how!
Jenn
May 28, 2006 22:38:55 GMT
So when is the baby coming round to my house to put mine to shame?
street
6.2 ft/lbs of talk
May 28, 2006 22:54:38 GMT
Didnt take you long to start making her look pretty did it!?! Good work
Mike D
@v8mike
May 30, 2006 20:45:40 GMT
Yesterday saw the following done Starting at the front: Stock suspension: Stripped: New bits: New bits coppergreased up: More new bits: New v old: Hilo's fitted: New v old bottom arms and tie rods: New bottom arms and tie rods fitted: Old hubs, bearings and knuckles: New bearings and knuckles fitted:
Mike D
@v8mike
May 30, 2006 20:49:55 GMT
front rebuilt with the new bits: New wheels: Fitted: About the right height: Looking good: Moving to the rear: Old setup: New Setup: Rear wheels fitted: a bit high.. A bit low!... last pic of yesterday. its raised a bit now.. and on the old wheels as we didnt get the arches fitted Mike
May 30, 2006 21:02:46 GMT
A grand job mate...you must be well pleased! :)Is that workshop at your home?
Jenn
May 30, 2006 21:02:47 GMT
Laaavley. You know there's a mini in my garage that could do with some work when you're done
May 30, 2006 21:22:12 GMT
bloody marvellous!!!
Mike D
@v8mike
I wish that workshop was at my house but it's at my mates. Jenn, i'll pop it down when the wheels are on and the exhaust and carb too when i've finished i don't mind getting stuck in if you want to have a few weekends on yours? Its just settling down on the new sus at the mo, seems to have improved the handling no end but i think i'm running a bit too much neg camber at the front. and now its lower the exhaust catches the speedbumps at work. Oh Well..... I may get a bit more done tomorrow evening with any luck
Last Edit: May 31, 2006 12:05:46 GMT by Mike D
you don't hang about do you. DOn't let my mrs see this or she'll be after another Mini...
Mike D
@v8mike
The suspension seems to have settled now, its a bit low! needs raising a bit to stop the wheels catching the arches! Tonight will hopefully see the new arches and wheels fitted, or at least ready to fit after spraying Mike
VWDan
VW Jetta MK1, VW Caravelle 1.9TD, Audi A6 Tdi Avant
Looks just about right to me.... ;D
If only everything in life was as cool as a retro VW racer.
Mike D
@v8mike
yesterday was another 12 hour day on the mini, it doesnt look like we did a lot, but there was a huge amount of work in trimming the arches and getting them to fit correctly! here we go.... old subframe bush was broken, no wonder the handling felt a bit odd! old v new all fitted up castor, camber and tracking set again wings cut to clear the new wheels new arches all trimmed up and fitted back on its wheels and some pics from this morning in the light I'm well happy with the result 8) carb and exhaust next then.....
Mark
That is stunning. Black handles look awesome too. don't change them. As long as you keep it mint, you'll never have any probs selling that Are you gonna fit a stage 1 kit, or just an exhaust? If you're just fitting an exhaust, don't bother with a bigger carb as it wont give you any extra power
Mike D
@v8mike
i thought a stage 1 kit was just pretty much an exhaust and filter? I've got a full exhaust and lcb, and a 1 3/4" SU and K&N filter to go on. When we just put an exhaust and carb on my old 1000 it made masses of difference... Looks like its going to get a central oil pickup pipe, and maybe a cam too... don't mess with the daily driver eh?!
Mark
Well if you put on the LCB, you're going to have to change the inlet manifold too, as the standard item is cast and the inlet and exhaust manifolds are joined together. Then you have a stage 1 kit!
What exhaust are you fitting? If you're planning on fitting a cam (SW5 is my recommendation) then fit the HIF44. Otherwise, the HIF38 is fine.
looking Good...amazing how a set of nice wheels and arches can change the look of a motor...on the engine side of things i can say from experiance that a hif44 will work fine with or without an uprated cam..as long as you get it tunned up ...before the big end went on my current engine i had a maniflow stage2 lcb fitted straight through exhaust and a hif44 carb with alloy inlet manifold..worked a treat. But i think the extra grunt it released is what upset the big ends...never mind good luck with it all great looking mini very cool
