Those scimmie steels look excellent. I actually prefer them to the alloys despite their hens teeth factor. Scimitar rims wouldn't fit...those are Weller Motorsport rims, picked up very near to my house from a guy that had some great stuff tucked away! They look awesome, by the way.
Last Edit: Dec 5, 2008 14:31:39 GMT by rmad
looking good.
Matt
saw these in the dish thread and they looked vw lol
lightbulb ;D
2001 HONDA CT110 (NOT RCV)
BiAS
Insert witty comment here
Club RR Member Number: 147
Like them alot! Saves the Dunlops getting eaten by the salt too!
(car+wheels)-rideheight=WIN
Those look brilliant!
markbognor
Club RR Member Number: 56
Those scimmie steels look excellent. I actually prefer them to the alloys despite their hens teeth factor. Scimitar rims wouldn't fit...those are Weller Motorsport rims, picked up very near to my house from a guy that had some great stuff tucked away! They look awesome, by the way. I must have got the wrong end of the stick about where they came from. I was having some problems keeping it together this morning.
Seth
Like them alot! Saves the Dunlops getting eaten by the salt too! As we're being pedantic on the wheel front they're not Dunlops but Firestone BRM's Got some front wishbone stuff to do for the MOT now (due by end of Jan) and have all the bits so might get on to that this week.
Seth
Got some front wishbone stuff to do for the MOT now (due by end of Jan) and have all the bits so might get on to that this week. And I have.... These cars suffer from a problem with the front suspension in that the main outer trunnion bolt passes through the this pressed steel wishbone and ovber a period of time wears the holes oval leading to excess play. I've already replaced the wishbones on both sides once and I discovered the problem was reoccuring when I changed the shocks earlier in the year. An old bodge is to weld a washer to the wishbone and you could actually do this in situ hence it was/is a popular get through an MOT lash up that would probably wear out in no time. I wanted to make an improvement as I don't want to change everything again anytime soon and decieded to improve on this "bodge" with a spare pair of wishbones. So I turned some thick "washers", reamed the bores to be a good fit with the bolts (much better than a regular loose fit washer) and welded them to the wishbones. I also decided to splash out on some SuperFlex bushes for them having been recomended them over other poly bushes. Might tell Mrs_Seth that's here birthday present done So today I had dry weather to fit it all. Here's the wishbone I removed from the pass side with a very oval hole. The other one was similarly worn. I had to get longer bolts to take account for the extra thickness and here's everything back together with new nylocs all round. Will have a more thorough look over the car but I don't think there's anything else to do for the MOT this year.
Nice one Seth, when i need the suspension sorted on the Capri i´ll be round to have a natter mate!
Nathan
Dec 10, 2008 11:48:37 GMT
Front sus on the Midget does exactly the same, bloody things!!!
Seth
Hoorah! MOT for another year and a bit Popped in to see Keefy at Retro Custom while I was in the area and the track down to their workshop was the first bit of proper snow I've driven on with these new tyres. Mightily impressed. I "played" a bit and could brake really quite sharply without locking up.
DutyFreeSaviour
Great 'proper' fix on the suspension Seth. I'll be taking a look at the Spit this evening as I'm sure they're the same layout Congrat's on the ticket - and the 'new' steels look fantastic it has to be said . John
Seth
Cheers John. Yep Spit is identical. I could do you a pair of wishbones as per mine on an exchange basis if you want me to?
DutyFreeSaviour
I'll do you a deal mate - snowed under with the Big Six's at the minute but want this done asap. I've got a few spare TR6 steels, will hand over some if you're still interested. I need the space TBH. Will PM you once I've plowed through and sorted some out for you. Sound fair enough?
John
Seth
I'll do you a deal mate - snowed under with the Big Six's at the minute but want this done asap. I've got a few spare TR6 steels, will hand over some if you're still interested. I need the space TBH. Will PM you once I've plowed through and sorted some out for you. Sound fair enough? John Sounds good to me! I would like your old wishbones a some point (though there'd be no rush) or I'd be stuck without spares should I need to go through it again.
DutyFreeSaviour
That's a given - I'll sort out the steels and I'll rip apart the Spit when I can get over to drop all of it together. Plenty of warning will be given
Seth
Feb 22, 2009 16:01:54 GMT
The old Yazaki rev couter I had clamped to the column was a bit small and didn't give an accurate reading. When the flimsey bracket I'd lashed together broke some months ago it just got removed and put to one side. Had another tach "in stock" though so finally got round to fitting it today. I made up a cardboard template for the new pillar mounting a couple of weeks ago. Used it to mark a piece of aluminium sheet. The scribed another circle about 6mm inside and went roudn it with the centre punch. Drilled on the punch marks first with 5mm, then 10mm. Clamped it to some wood to help prevent the drill catching. Then on with the filing. Finished shape. Put the fold in using angle iron in the vice and marked/drilled mounting holes. Transferred these to the car using masking tape. Screwed on. Much betterer ;D Should take it back off really and smooth the surface to match the switch panel...
Feb 22, 2009 17:05:11 GMT
Not a bad place to put it. I keep meaning to put a tach on mine as well.
Mr K
Feb 22, 2009 17:56:43 GMT
looks really good!
what about crackle black finish, that would look great!
Seth
Feb 22, 2009 19:30:38 GMT
Not a bad place to put it. I keep meaning to put a tach on mine as well. Yeah, Its to big to go underneath the dash where you cant see it anyway, I didn't want to chop into the dash pad which is otherwise perfect and was under strict orders for it not to block visibility She's happy with it there MrK, Crackle black is an idea but I do like raw aluminium... Oh, I finally fitted the auto electric aerial on Friday too so I'm really in the good books at the moment. ;D
