fomoco
If u don't go sideways atleats once a week u will feel depressed!!
ahright folks am new here said high on chat page heres a couple of me motors! she was my first car when i was 17 and had her since, been through many phases, nothin special but now a toy for knockhill. back when she was on the road, not much changed since really, just black bonnet n no interior with buckets n harnesses. the important bit is this: the powerplant 1800 zetec running my custom inlet and single carb setup with 2L cams and a 4branch exhaust with ashley straight-through ;D oh and a 4 speed box. fun and keeps up with XE powered novas! a cheeky vid from day i got her runnin!! ignore focus rims was wating on tyres!! media.putfile.com/video-003233and i tow her with the me van: will try and get pics of the anglia and 'tina up after crimbo will need to upload em, but i know use will all be into em more!!!!!!! ;D ;D
Last Edit: Dec 30, 2005 11:58:22 GMT by fomoco
Davenger
It's only metal
Club RR Member Number: 140
My escortsDavenger
@dminifreak
Club Retro Rides Member 140
Love the ecsy, proper sleeper, bet it's loads of fun. Van looks cool too, orange light is spot on
van looks way better there than in your sig...it needs sign writing guessing your in scotland then?
fomoco
Dec 23, 2005 10:47:53 GMT
yep bonnie scotland it is, howd u guess
My escortsarthurbrown
@GUEST
Dec 23, 2005 10:53:45 GMT
I had one of those Mk4's once.
Worst car I've ever had. Utterly Foul.
That said, it did have a turd 1300 hcs engine, not a spangly zetec.
fomoco
Dec 23, 2005 11:03:16 GMT
yeah i ran 2 different 13 chappers but 65 horses and reving to 4k max isnt any use for pushing vauxhalls round the track!! a pic of engine bay: don't get me wrong for runabout purposes, fuel economy the hcs is the bomb!
Last Edit: Dec 23, 2005 11:05:32 GMT by fomoco
GJM
Alloy engines; like communism- great in theory.
Dec 23, 2005 11:31:39 GMT
That van is great Wouldnt mind that Zetec in my mk2 Orion either ;D
Dec 23, 2005 15:52:13 GMT
yep bonnie scotland it is, howd u guess coz knockhill is in scotland
street
6.2 ft/lbs of talk
Dec 24, 2005 16:57:15 GMT
Fantastic! 4 door sleepers are where its at Is that an XR2 carb fueling that zetec?? I fancied doing the same thing with mine, but i never could find out what jets people use
fomoco
Dec 24, 2005 18:23:08 GMT
Fantastic! 4 door sleepers are where its at Is that an XR2 carb fueling that zetec?? I fancied doing the same thing with mine, but i never could find out what jets people use yeah mate earlt squaretop xr2 carb, it done bout 300 miles before i got it!!! just runnin the standard jets at the mo n seem to go good, however flat out in 4th i do loose some power to underfueling at times so will play bout with that next year!! need to make a change to water piping too!
street
6.2 ft/lbs of talk
Dec 24, 2005 21:06:18 GMT
Fantastic! 4 door sleepers are where its at Is that an XR2 carb fueling that zetec?? I fancied doing the same thing with mine, but i never could find out what jets people use yeah mate earlt squaretop xr2 carb, it done bout 300 miles before i got it!!! just runnin the standard jets at the mo n seem to go good, however flat out in 4th i do loose some power to underfueling at times so will play bout with that next year!! need to make a change to water piping too! Kool nicely modded inlet manifold ;D I might have a pop at throwing in a zetec and running it off the standard carb too then Some people are using the DGAV from the grannys and capris, but they're getting a bit hard to source Whats your water pipe prob? Does she overheat?
fomoco
Dec 24, 2005 23:29:51 GMT
yeah i know bout usin the capri carb, but i figure its made for a 2.8/3 litre i think?? so not really suited to 1800!! we shall see i suppose.
yeah she runs hot mate, just below red but cant have her idling when hot cos will overheat!!
i originally was gona run water through inlet so i have plumbing for that but decided didnt need it, so it kinda goes the long way for a shortcut. just needs a redesign as i think i can make it better!!
u shoiuld go for it mate, zetecs get a lot of bad press but i thot il give it a bash and well chuffed!!
keepin uo with 2L 16v novas = a smile on my face!!
if u need any info mate on changes just give me a holler more than happy to help!!
;D
Davenger
It's only metal
My escortsDavenger
@dminifreak
you say it uses an XR2 carb. I presume you had it re-jetted for an 1800 If not, it'll be running pretty lean which might cause your over heating problem
street
6.2 ft/lbs of talk
Dec 25, 2005 18:07:54 GMT
yeah i know bout usin the capri carb, but i figure its made for a 2.8/3 litre i think?? so not really suited to 1800!! we shall see i suppose. yeah she runs hot mate, just below red but cant have her idling when hot cos will overheat!! i originally was gona run water through inlet so i have plumbing for that but decided didnt need it, so it kinda goes the long way for a shortcut. just needs a redesign as i think i can make it better!! u shoiuld go for it mate, zetecs get a lot of bad press but i thot il give it a bash and well chuffed!! keepin uo with 2L 16v novas = a smile on my face!! if u need any info mate on changes just give me a holler more than happy to help!! ;D Thanks mate ;D I read about using the later CVH or HCS coil to sort the ignition side of things, it was just the fueling that looked like the expensive/complicated bit. I'll let you know how i get on if i decide to go the zetec route
Mr K
Dec 25, 2005 18:29:37 GMT
yeah i know bout usin the capri carb, but i figure its made for a 2.8/3 litre i think?? so not really suited to 1800!! we shall see i suppose. yeah she runs hot mate, just below red but cant have her idling when hot cos will overheat!! i originally was gona run water through inlet so i have plumbing for that but decided didnt need it, so it kinda goes the long way for a shortcut. just needs a redesign as i think i can make it better!! u shoiuld go for it mate, zetecs get a lot of bad press but i thot il give it a bash and well chuffed!! keepin uo with 2L 16v novas = a smile on my face!! if u need any info mate on changes just give me a holler more than happy to help!! ;D Thanks mate ;D I read about using the later CVH or HCS coil to sort the ignition side of things, it was just the fueling that looked like the expensive/complicated bit. I'll let you know how i get on if i decide to go the zetec route don't you already have twin 40s on your scort? so u just need a Zetech manifold
street
6.2 ft/lbs of talk
Dec 25, 2005 19:41:18 GMT
Yeah thats true i do, but I'm thinking its gonna cost big money in jets for the 40's to set them up for the zetec...... the jets alone for the CVH cost £150 I figured it would be cheaper to sell the CVH with its 40's and do a cheap XR2 carbed zetec...... Now i don't know what to do really....... I'm so easily swayed!
fomoco
yeah i know bout usin the capri carb, but i figure its made for a 2.8/3 litre i think?? so not really suited to 1800!! we shall see i suppose. yeah she runs hot mate, just below red but cant have her idling when hot cos will overheat!! i originally was gona run water through inlet so i have plumbing for that but decided didnt need it, so it kinda goes the long way for a shortcut. just needs a redesign as i think i can make it better!! u shoiuld go for it mate, zetecs get a lot of bad press but i thot il give it a bash and well chuffed!! keepin uo with 2L 16v novas = a smile on my face!! if u need any info mate on changes just give me a holler more than happy to help!! ;D Thanks mate ;D I read about using the later CVH or HCS coil to sort the ignition side of things, it was just the fueling that looked like the expensive/complicated bit. I'll let you know how i get on if i decide to go the zetec route yeah its the DIS ignition u need mate, just a module. luckily my scort started life as a 1300 hcs with that ignition so it was all there. little update weve just bought a 3door shell with konis all round and driled n grooved discs, green stuff pads, piper exhaust, and turbo rims for cheap from my mate, Zetec is now in that!!! ;D
fomoco
Dec 30, 2005 11:57:26 GMT
WATS WITH SUMONE CHANGIN THE TITLE OF MY THREAD? ? Ford Escort Hatch - 1990 & Ford Escort Van - 1990 isnt wat i named it! sounds pi$h.
Mr K
Dec 30, 2005 12:49:50 GMT
WATS WITH SUMONE CHANGIN THE TITLE OF MY THREAD? ? Ford Escort Hatch - 1990 & Ford Escort Van - 1990 isnt wat i named it! sounds pi$h. read the sticky at the top of the readers rides section, idealy your cars should be on seperate pages too. would of been one of the admins that changed it - i think Irocco was correcting all the titles.
fomoco
Jan 22, 2006 21:44:43 GMT
me dad bought a new shell for the track so we filled the gap between xmas n new year with switching the zetec in, heres some pics of new shell... -konis all round -green stuff pads n red dot drilled/grooved discs -turbo rims -piper zorst + zetec power!! to come: -oil cooler -bigger jets -more fastness
