Last (hopefully!) of the mechanical work being sorted within next couple of weekends - I'm having the front suspension parts machined to take poly bushes as I couldn't get original size parts. Then I'm hoping to MOT it, drive it a bit to sort out teething problems and then tidy the body up before a respray in standard Mustard Yellow with matt black steels as I can't find alloys to match front and rear.
1.6 16v 4A-GE engine with T-VIS from Corolla AE86
T50 gearbox from AE86
oil filter relocated to inner wing using Mocal kit
oil cooler from Corolla AE92
recored Daihatsu diesel radiator
Peugeot cooling fan on front of radiator, blowing into engine bay
battery relocated in boot
AE86 fuel pump fitted in modified standard fuel tank
home-made inlet trunking with Pipercross foam air-filter
home-made down-pipes
home-made 2" exhaust from downpipes back
home-made front strut brace
custom made front coil springs lowered 1", uprated 25% with Monroe struts uprated 15%
Leda modified rear leaf springs lowered 1", uprated 25% with new standard dampers
nylon rear suspension bushes by a guy in work
steel wheels front Peugeot 5x13 with 155/70 tyres; rear Ford 5.5x13 with 185/60 tyres
standard rear axle for now, AE86 axle waiting to be narrowed, sometime, maybe!
Girling racing brake master cylinder with remote reservoir
239mm Ford vented discs on front with AP 4-piston calipers
home-made clutch master cylinder mounting under dashboard
AE86 clutch master cylinder using remote reservoir
stainless steel braided hoses for all hydraulics
home-made brake caliper mounts, engine mounts, gearbox crossmember
one-off prop-shaft by local engineering works
shortened AE86 gear lever with alloy gear-knob by another guy in work
Cobra bucket seat with home-made mounts
Smiths tacho from Dolomite Sprint in place of combination fuel/water temp gauge in original dash
alloy centre console with water temp, fuel, voltmeter, oil pressure gauges
alloy/leather 3-spoke steering wheel found on an old Celica
Sparco alloy pedals
rear :-
front :-
im1.shutterfly.com/procserv/47b5da00b3127cce9114a0081a4c00000010108AbMWjFw5aOM[/img]
interior :-
engine :-
what standard engine looked like :-
Sparco alloy pedals
rear :-
front :-
interior :-
engine :-
