Volkswagen MK1 Caddy Sport Pickup, J reg/1991, the car is garaged at the moment but the mileage from memory is 102,500, the Sport model came standard with the 1.8i 8V K-jet type engine, has lower suspension than a 1.6 petrol/diesel caddy and has a subtle body kit as standard that is colour coded.
The Caddy is Alpine white and the body is in very good order, not concours but very good with no rust. The load bed area is body coloured and one of the better ones you'll find, with no holes. The Caddy is also fitted with a brand new tailgate from VW, which cost an arm and a leg on its own! The Caddy has also benefitted from the following:
Seats removed, floor pan painted with enamel
Re-conditioned rubber flooring fitted
Underside fully cleaned
Underside Wax-oiled
Rear roll pan valance fitted
Full exterior re-spray in Alpine White 2007
2nd hand windscreen fitted professionally
New rear sliding window and new rubber fitted professionally
New dash board windscreen vent inserts fitted
New German style number plates fitted
New rear fog/number plate light fitted
New rear red reflector markers fitted
New rear lights fitted
New side mirrors fitted
New chrome side trim fitted
New 4 lamp de-badge grill fitted
2 New outer Hella headlamps fitted
2 New Bosch spoiler windscreen wipers fitted
4 New G60 15” steel wheels/Toyo Proxes 195/45/15 tyres fitted (done 500 miles if that)
The engine runs very well and sounds very healthy, it had a new cam belt at 101,500 miles, new oil & filter at 101,600 along with many new other parts:
Rocker cover gasket replaced
Cam shaft oil seal replaced
LH/RH C.V. Gators replaced
LH/RH Flexi front brake pipes replaced
LH/RH rear wheel bearings replaced
LH/RH complete front suspension top mounts replaced
Distributor cap/Rotor arm replaced
Plugs replaced 101,700 miles
Plug leads replaced 101,700 miles
New quiet sport full stainless steel exhaust inc 4.2.1. Manifold fitted 101,800 miles.
New air horn was fitted as the old one was lame.
New aluminium power rohr pipe.
Also it has a brand new fast road Sachs clutch fitted this month and a new battery.
All in all a very nice reliable Caddy Sport, ready to go and doesn't need anything, but to be looked after and enjoyed.
MOT - Dec 08
TAX - Sept 08
As I've stated Cam belt done, full stainless exhaust system inc manifold, oil/filter recently changed and has K&N panel air filter also any other wear and tear items that were needed have been changed, new wheels/tyres, so basically nothing to worry about.
Price - £4,200 ovno.
I'm based in Swansea, South Wales, viewings at wk-ends only due to work, any interest by PM only please.
Up-to-date pictures will be posted after the wk-end.
7X15 nearly new mint condition ATS Cups available with nearly new 195/45 Uniroyal Rainsport tyres for an extra £400.
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01580.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01594.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01589.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01588.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01581.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01583.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01582.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01584.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01591.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01576.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01577.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01587.jpg)
![](http://i218.photobucket.com/albums/cc181/Ratfink91/DCP01586.jpg)
Underside Wax-oiled
MOT - Dec 08
TAX - Sept 08
