Mike
East Midlands
Jan 11, 2008 12:38:26 GMT
I've had these sitting around for a while, its about time I admitted i'm never going to use them for anything... Now on ebay hereThe markings in the centre of the wheel seem to suggest they are made by a company called Seral (if anyone knows different, let me know), they are 13" x 5.5j and ET38. The lad I bought them off had them on a Mk2 Polo, so i'm assuming they are 4x100. They had previously been caked in thick black paint (probably hammerite) and i've spent hours (and hours) stripping and sanding them back. I've got most of the paint off, but they are still rough in places and need finishing off. There is also some kerbing on them, but no horrific gouges. The wheels all have Nankang 185/60 tyres on them with varying degrees of tread, the one pictured has 4-5mm the others a bit less. Think they are all legal though. The wheels are in Lincoln.
Last Edit: Jan 21, 2008 22:04:06 GMT by Mike
g40jon
Jan 11, 2008 12:45:40 GMT
these look very much like ats phonedials and if i were you i would be advertising them on ebay as they should fetch a bit more than £50
Jan 11, 2008 13:28:01 GMT
I may be totally wrong but they look a little Italian, fiat maybe, so they might be 4x98 could be worth checking.
Jan 11, 2008 14:04:04 GMT
1st dibs please if they are 4x100, only in Doncaster thanks
Jan 11, 2008 14:36:54 GMT
@pistonbroker on Twitter
Mike
East Midlands
Jan 11, 2008 15:00:09 GMT
They are similar, but the Audi ones are more squared off. I've just been and measured them, and they are pretty much dead on 4x100 as far as I can tell. (using a metal ruler and a squinted eye). I'll try one on my Astra when it stops raining.
Last Edit: Jan 11, 2008 15:00:43 GMT by Mike
g40jon
Jan 11, 2008 15:17:22 GMT
g40jon
Jan 11, 2008 15:21:26 GMT
Mike
East Midlands
Jan 11, 2008 15:55:00 GMT
They could be, the finish on those is as bad as mine was before I stripped them. They are very similar, but i'm not so sure. Those Phonedials have 6-holes, my set has 8. Would they do a set with more holes? EDIT: I've found one of their original applications... I found this picture (and the brief explanation) hereCheers g40jon, i'd not have delved so deeply if you hadn't been so insistant they about what they were!
Last Edit: Jan 11, 2008 18:37:29 GMT by Mike
Jan 11, 2008 15:57:56 GMT
when can i collect mate
Mike
East Midlands
Jan 11, 2008 16:10:15 GMT
PM sent
Jan 11, 2008 16:39:37 GMT
If they're off a Yugo they're going to be 4x98, aren't they?
Mike
East Midlands
Jan 11, 2008 18:43:10 GMT
If they're off a Yugo they're going to be 4x98, aren't they? I would have thought so too, but I put up a post on wheel-whores.com to find out what they were, and someone had seen a set that were 4x108, so they maybe were made with different pcd's? Here's a set on a VW Polo. (turns out these may be the exact set of wheels i have) I'm going to trial fit one on my Astra in the morning, just to check.
Jan 11, 2008 21:37:02 GMT
mike let me know fella as I defo need 4x100 as they'll be going on my caddy, ta Glenn
Mike
East Midlands
Jan 12, 2008 12:39:11 GMT
Right, i've tried these on my Astra this morning, and my wheel bolts aren't long enough to reach the holes. Great. The centre bore is slightly bigger than the Astras 56.1mm, so they were sat flat, but there is too much depth to the bolt holes to seat the bolts. The holes looked lined up as far as i can see, but i can't be definite without tightening them up.
So it looks like we're back to "possibly" 4x100. Dammit.
Veedubmaster: As i can't say for deffo that they are 4x100 are you still interested? I understand if not, and if you aren't, i might whack them on ebay instead..
Jan 12, 2008 21:49:58 GMT
mike, just sent buster from club polo a quick pm, cant see if they fit on his polo why they shudnt fit the caddy, if ok with you i'll still take 1st dibs til 2moz, and let u know am 2moro for defo.....hope this is ok mate
Mike
East Midlands
Jan 13, 2008 13:39:27 GMT
thats fine mate
Mike
East Midlands
Jan 17, 2008 18:41:09 GMT
*Bump* Still for sale.
Jan 17, 2008 20:32:28 GMT
Those are Yugo 65GLX alloys and are DEFINATELY 4*98.
Wobble bolts will allow 4*100 fitment (or sheer willpower and graunching them on)
Mike
East Midlands
Jan 20, 2008 15:07:03 GMT
bump for ebay-ing
