There's a company down the road from me called Factory Five Racing
They produce one of the best Cobra replicas I've ever seen at a rather good price.
The kit price starts at $12,990 (about 6850GBP)
Comes with:
I was thinking Small block Ford 289 with this throttle bodies:
Or if I win the lotto, get a Ford 5.0 32V DOHC Cammer Crate
$15k USD
I'll use the same TWM throttles.
Comes with:
1. Body: Hand laid 3/16” laminate with vinylester resin. Comes with separate and complete doors, door liners, hood, hood liner, and trunk with aluminum trunk liner. Doors and trunk are hinged and mounted.
2. Frame: Complete jig-welded original style 4” round tube frame. Includes all mounts ready to accept small block Ford and 1987-2004 Mustang running gear. Kit can be ordered to accept a wide variety of engines/suspensions.
3. Chassis Aluminum Panels: Includes over 40 CNC cut, pre-formed aluminum panels for cockpit, trunk, and engine bay.
4. Front Suspension: Includes high quality Bilstein brand mono-tube, rod-end, coil-over shocks, tubular upper a-arms with ball joints, adapter brackets and all grade-8 mounting hardware.
5. Rear Suspension: Standard kit includes all brackets, fasteners and axle straps to mount your 8.8” rear end.
6. Roll Bar: Complete roll bar assembly ready to bolt directly to finished frame mounts.
7. Side Exhaust Assembly: Comes w/pair of 4-into-1 side steel side pipes, straight tubes, gaskets, and mounting hardware.
8. Brake/Fuel Lines: Pre-flared brake and fuel lines (3/16”, 1/4" and 5/16”) with fasteners.
9. Lighting: Original-style British and Lucas lighting, including DOT headlights, front amber turn lamps, DOT rear red, twin filament tail-lights, and chromed original license plate light.
10. Exterior and Interior Accessories:
Original style Chrome-on-Brass vintage windscreen,tinted.
Authentic 3.5” Aston roller gas cap, polished cast aluminum with adaptor kit and all fasteners.
Authentic 14” or 15” wood and aluminum steering wheel, w/polished aluminum boss and small center badge.
Authentic British style chrome latches, handles, and locks.
Authentic inside rear view mirror and side view mirror.
Original design quick-jack competition bumpers.
Original design pleated seats and mounting hardware.
Authentic chrome shifter ring and boot.
Original design chromed reverse canted shifter.
Driver and passenger professional 3” wide H-harnesses made by SIMPSON, frame mounted w/fasteners.
Covered aluminum dash with dash buttons, toggles and indicator lights.
Competition hood pins.
High quality laser-cut aluminum side louvers.
Original design interior trim package includes door pockets, dash cover, shifter cover, and emergency brake boot.
11. Weather-strip/Seals: Adhesive backed press-on trim, weather-strip, cool “expanda-foam” sealant and grommeting.
12. Carpet: Complete carpet set, pre-cut and packaged separately.
13. Gauge Package: Mustang gauge conversion kit with machined bezels, spacers, wiring extensions, fasteners and lenses.
14. Steering Kit: Steering adapter kit to utilize Mustang steering rack includes upper shaft, pillow block, flange bearing, fasteners, lower shaft and u-joints. Features a collapsible column.
15. Cooling Fan: Electric cooling fan and mounting hardware, extensions for radiator hoses, and all necessary fasteners.*
16. Oil Filter Relocater: Relocate kit comes with all hoses and hardware.*
17. S B Performance Filter and Fan Belt: Air filter kit and hardware*.
18. Battery Tray and Cable: Battery tray, hardware, and pre-cut, pre-assembled 4-gauge positive cable w/terminal covers.
19. Pulley Kit: A/C replacement pulley kit and custom length fan belt* with fasteners.
20. Assembly Manual: Bound assembly manual that is over 200 pages long.
21. Fasteners: Over 1500 top quality zinc plated, chrome and stainless steel USS and SAE fasteners, numbered and packed individually by assembly.
22. Accelerator Cable Assembly: includes the cable, return spring and retainer
Owing to the complexity of different Mustang parts from 1987 to 2004, we have two simple packages that address these parts differences. Basically, all the kit parts that we provide are interchangeable except for a few items. Customer who use Mustang parts from 1996 to 2004 get a few extra parts and don’t need some others. Parts identified in the preceding list with an asterisk * are replaced with the following parts for customers using 1996-2004 donor cars.
Ignition Switch: Includes the key, switch and electrical connectors to use with 96-04 parts.
Brake Hydroboost Mount Assembly: For customers using 96-04 Hydroboost brakes. Includes tool.
96-04 Radiator Mounting Assembly
4.6L Oil Pan and Transmission Mount Assembly: The later model oil pans are too low.
Fuel Filler Tube Assembly and Radiator Hose Assembly
A/C Eliminator Bracket Assembly and Air Filter Mount Assembly
$15k USD
