street
6.2 ft/lbs of talk
Aug 14, 2007 11:15:20 GMT
Went and baught the wrong gearbox for my Escort project! It now emerges that I need a MK2 FIESTA DIESEL GEARBOX! Must be from a mk2 Fiesta, and must be a diesel. I actually need 2 of them, but obviously if you have one I will be interested If you see one while your scavenging in your local scrapyard, give me a shout also! Thanks RR'ers!
Aug 14, 2007 11:45:54 GMT
left a wanted for ya with fiesta club, don't hold ya breath like.
street
6.2 ft/lbs of talk
Aug 14, 2007 14:41:18 GMT
Thanks a lot bud!
Aug 14, 2007 16:12:04 GMT
why do you need a FIESTA DIESEL box
find me on facebook to see photos of things I'm selling off !!! All Forshow or ebay all-4-show-uk
street
6.2 ft/lbs of talk
Aug 14, 2007 17:44:46 GMT
It has the longest ratios of any of the BC type gearboxes I was going to use an MTX75 box out of a mk6 Diesel, but it seems that it's going to be too much hassle to get it to fit
Aug 14, 2007 18:20:44 GMT
the engines are useful too if you lay your hands on one. the pistons can be used to stroke pinto's, the cranks can be used to stroke crossflows
street
6.2 ft/lbs of talk
Aug 19, 2007 16:10:30 GMT
A little bump for all those scavengers that have been down the scrapyard this weekend, if you saw one give me a shout!
Aug 19, 2007 20:29:47 GMT
is it not the same as an escort 1.8 diesal box??? ive got one in the garage
madmart
love is: valvebounce in top gear
Aug 19, 2007 22:57:47 GMT
mk4 and early 5 boxes are the same, IIRC oh and mk3 fiesta. if you get stuck for one/two pm me i might be able to help, ive goto check at work at what ones are there.
Aug 19, 2007 23:14:13 GMT
mk4 and early 5 boxes are the same, IIRC oh and mk3 fiesta. if you get stuck for one/two pm me I might be able to help, ive goto check at work at what ones are there. its the mk3 & (some) mk5 boxes that are the same mate the mk4 is a box on its own (unless it was a late mk3 ) as i thought i had a spare box for my mk4 3i but it was a mk3 3i box so had to go & buy one
street
6.2 ft/lbs of talk
is it not the same as an escort 1.8 diesal box??? ive got one in the garage It's simular, but the ratios on the Fiesta boxes were a bit longer, which will make all the difference with this twin engined project. I'm getting a bit desperate now so I might have to just use another XR3i gearbox for the time bieng, as it's holding up the whole project! Be nice to get it right first time though, cos i've got to get the bellhousing welded up whichever one I go for
it know its alot of work but might be worth just using a standard box as a practice run and something to work around and keep this project moving ill keep my eyes open for you tho fella
street
6.2 ft/lbs of talk
Aug 20, 2007 12:30:49 GMT
it know its alot of work but might be worth just using a standard box as a practice run and something to work around and keep this project moving ill keep my eyes open for you tho fella Thanks bud Yeah I think your right, i'll just bung a standard box in for now, itching to get the beast on the road now!
