filmidget
East Midlands
Mostly Lurking
Now I am done to one Scirocco project, I can start thinning done the considerable 'stock' of parts I have collected over several years and broken cars.
There is literally too much to list including suspension bits, engine and transmisson, body parts, interior and exterior trim...
I will catalogue eventually for a proper advert, but if there is anything particular anybody is looking for I can dig it out and bring it to RR show@Mallory.
Prices are going to be reasonable as really I need the space!
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
What have you got in the way of 8v inlet manifolds Phil ? Need possibly an Injection one to cut up for bike carbs and a Carb one to port to match my new ported head and take a Weber Have you got a Weber as well ?? just in case
filmidget
East Midlands
Mostly Lurking
I have a std carb inlet, but don't think I have a spare injection one (still undecided whether to go 16v or not ) I also have a Weber DMTL c/w all the adapter bits EXCEPT it has no jets, and looks a bit old and ropey, but I fitted a Weber service kit and it helped my 1800 make 125bhp. I guess the jets won't be a problem, as you're sticking it on a modded engine and so will be having it set up on rolling road anyway? If not I have the numbers for the std jets knocking about. I also also have a butchered K&N filter that you can have with it (Although if all this is for the syncro I would stick with the std intake for fear of carb icing). £40 the lot at Mallory? Can I also interest Sir in a GTI cam to compliment that ported head? I have both solid and hydraulic lifter flavours...
I have a std carb inlet, but don't think I have a spare injection one (still undecided whether to go 16v or not ) I also have a Weber DMTL c/w all the adapter bits EXCEPT it has no jets, and looks a bit old and ropey, but I fitted a Weber service kit and it helped my 1800 make 125bhp. I guess the jets won't be a problem, as you're sticking it on a modded engine and so will be having it set up on rolling road anyway? If not I have the numbers for the std jets knocking about. I also also have a butchered K&N filter that you can have with it (Although if all this is for the syncro I would stick with the std intake for fear of carb icing). £40 the lot at Mallory? Can I also interest Sir in a GTI cam to compliment that ported head? I have both solid and hydraulic lifter flavours... Sold sir but the head I have just collected has a 272 Fast road/Sprint Newman cam in it Could do with a Cam cover and studs if you have them though ? Do you still want those Subframe bushes for the audi ? And I have found one of the Bumper pods - still looking for the other one though.... Got a bare glass Bonnet pod that needs some work as well if you fancy it for the full rally s1ag look again ? ;D Its not the one that was on there but would fit easily with a bit of Glass Layup
filmidget
East Midlands
Mostly Lurking
Cam cover I have (no charge).
Studs... don't bother. Instead get the 'improved' cam cover gasket set from the dealers - it includes a proper metal/rubber (reuseable?) gasket, and a set of new studs and nuts of a slightly different design, all for a remarkably reasonable £8-odd!
Light pods, both bumper and bonnet, I am very interested in. Subframe bushes I fear I would never get around to fitting, plus it does get used 'off-road' so I can see solid bushes causing trouble...
You going Saturday or Sunday or both?
I`ll be there on Saturday, possibly come across Friday night for the RR BBQ ? we`ll see I have the Bonnet pod up here so I`ll bring that along, Bumper pods you can have but they are not up here with me, I will sort them out and bring/send them up when I can get 1/2 a day to get the garage organised again. Subframe bushes I`ll ebay then Cheers Dom
filmidget
East Midlands
Mostly Lurking
Hope to see you on Saturday. I will PM my mobile number.
BTW you are welcome to some studs if you want them, it's just a lot of people don't know about the improved cam cover gasket - 357.2% better than those damned cork ones...
Cool
